2 stage boost
Old Apr 24, 2006 | 09:25 PM
tsrtrocse's Avatar
tsrtrocse
Default 2 stage boost
i undr stand that it is possible to have 2 stage boost on a cossie. with a flick of a switch you get a higher boost level. i under stand that the switch breaks the curcuit of the amal valve.
Is this true? and how do you set the 2 different levels?
CheeRS
Old Apr 25, 2006 | 07:09 AM
JamesH's Avatar
JamesH
It is something to do with Pin 16 (IIRC) Off the ECU!
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
Russ Payne
Sep 25, 2015 08:29 PM
