oops my bonnet flew open
Apr 24, 2006 | 05:50 PM
fitted my nice new radtec intercooler the otehr day and ignored a kid who told me to bash the cooler in a bit where trhe bonnet catch sits, anyway drive up the road, and bang, up the bonnet goes
anyone else found that the cooler fouls the catch and had to bash cooler in?
Apr 24, 2006 | 05:57 PM
Used to have a Radtec front mount no bashing needed on mine
Apr 24, 2006 | 06:05 PM
i bent the puller on mine, was a bitch to reach when i wanted to open the bonnet but it never flew up, just so that if the 1st catch goes the hook still works, it usually wont with a cooler in the way
Apr 24, 2006 | 06:08 PM
no such problems with a GRS
Apr 24, 2006 | 06:32 PM
No such problems with my Pace chargecooler !!!!
Apr 24, 2006 | 06:40 PM
Quote:
ditto i have a pace chargecooler and i have no problems
Apr 24, 2006 | 06:50 PM
Apr 24, 2006 | 06:51 PM
This has nothing to do with the intercooler,the bonnet catch did'nt hold the bonnet closed,end off.Regards Micky
Apr 24, 2006 | 06:54 PM
Quote:
Originally Posted by T28 RST
any solution??
Apr 24, 2006 | 06:58 PM
i took my catch handle off with a grinder it still locks down fine also i have bonnet pins fitted i no 2 people who have had bonnets fly up
Apr 24, 2006 | 07:19 PM
And me
what sort of ACTs are you's seeing with your chargecoolers?
Apr 24, 2006 | 07:20 PM
Apr 24, 2006 | 07:28 PM
so what do i do to cure it? bash the cooler in or grind the catch off?
Apr 24, 2006 | 07:39 PM
It happend to me wen i used to have a pace dbl capacity IC,
so took the catch off and fitted bonnet pins! Now i have a GRS,NO TROUBLE
Apr 24, 2006 | 07:52 PM
Same
Apr 24, 2006 | 08:12 PM
What was the damage then
I have an extra security measure in place to help prevent damage being done if this happens (don't want to fit pins) ŠTonyTurbo
Apr 24, 2006 | 08:27 PM
no one is really offering any useful advice here
Apr 24, 2006 | 10:52 PM
its nothing to do with the cooler, its normally to do wen the bonnet catch needs adjusting mate
Apr 24, 2006 | 10:55 PM
New bonnet catch with new cable, properly set-up won't give you any problems. The catch has adjustment on it, which if incorrectly adjusted won't allow the barb of the catch to full engage. It needs to pass the 'lever' on the slam-panel and pop into place. Also, make sure that the corner rubber supports are correctly adjusted. They should support the bonnet, but not prevent it from closing properly.
Apr 25, 2006 | 08:41 AM
fit some bonnet pins mate as an extra measure, that way it cant happen again
as i have heard of this happen a few times now, with different coolers as well
dont risk it (says me i aint even fit any yet!
Apr 25, 2006 | 05:15 PM
cool, i have bought a new cable as the on on there has broke from the handle
Apr 25, 2006 | 05:23 PM
sorry i forgot to ask, whuch part of the catch do i need? i got the cable but is it the female part or male?
Apr 25, 2006 | 09:58 PM
this is exactly why I fitted bonnet pins, just in case this ever happens!
not seeing above 40deg on my charge cooler at the mo, could all change in the hotter weather though
Apr 25, 2006 | 10:13 PM
You'll be f*cked in the summer then mate,I dont see over 32c on my GRS after a 20 min session at National Day in the middle of August,and thats at 18 psi boost,balls to the wall for 27 miles!!
Regards Micky
Apr 26, 2006 | 06:22 AM
good for you
I don't thrash the fuck out of my car and I've got no motorways over here to hold it flat out so I'm happy
gambo08
Feb 4, 2016 10:49 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
gingeRS
17
Oct 2, 2015 09:42 AM
DavidK
Sep 27, 2015 02:55 PM
