what clutch?
There must be someone who can advise me on what clutch set up to use on a Zetec Turbo engine thats running in a RS turbo with CTS Stage two plus box.
Is there a good quality one available that can withstand high levels of power and torque figures ???
Any help is welcomed on this matter
Originally Posted by Christian and Beccy
Might be worth sifting through the other thread in this section discussing clutches. Some good info in there amongst the shite!!
so from reading thro other topics, is a Alcon 6 paddle the best option available?? and using what cover, AP heavy duty?
Also who can supply the Alcon clutches
See here for the AP stuff.....
https://passionford.com/forum/viewtopic.php?t=174233
The Alcon is Ł350 for the 6-Paddle kit, but doesn't come with a release bearing. You need to use a Ford one.
Originally Posted by zetec-turbo
what would of caused this plate to break like this after about 6wks??
or was i just unlucky in having a bad one
That clutch is Fooooooked. Aside from the chunks out of it, the plates look VERY VERY blue and worn. What cover did you use with it?
i would still go for the heavier ap plate - C has explained about how the paddle's work on the other thread. I will point out that blue doesn't equal bad - its heat - and u will always get that will slippage. Remeber that the alcon will take the power - but if ur using it on the road - it will wear quickly. The proper way of solving this problem is using very heavy plates with a hydrualic conversion to make it manageable.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
