Blue smoke
Old Apr 21, 2006 | 08:10 AM
Gary F's Avatar
Gary F
Default Blue smoke
My cossie is starting to blow a little blue smoke out when on full boost mainly in the lower gears any ideas what could be at fault?
also my oil reading on the dash is around the middle mark on tick over but lately when ive been stuck in traffic it is starting to go a bit low can any one give me any advise
Old Apr 21, 2006 | 09:37 AM
cahzz's Avatar
cahzz
can you give a better description of when your getting the smoke, so youve said at full boost in the lower gears, what boost are you running? do you see any smoke on idle or on the overrun? are you seeing most smoke while boost is building or when max boost is reached?
maybe your turbo seals are letting alittle oil past causing some burning, pull off the induction hose to the front of the turbo is their any movement in the turbine, side to side in and out? sorry for all the questions just trying to help you sort this asap
Old Apr 21, 2006 | 09:39 AM
cahzz's Avatar
cahzz
i remember when mine smoked alittle and on further inspection the oil was way over the max, i replaced with fresh oil at the correct level and it was fine.
Old Apr 21, 2006 | 12:33 PM
Gary F's Avatar
Gary F
I can just see the smoke in my mirror when the car is around something like 5000rpm its stage 3 running 18psi and its when the cars actually boosting
Old Apr 21, 2006 | 01:02 PM
Damo V's Avatar
Damo V
turbo
wouldnt worry about the lower oil pressure at idke when hot, its just wheere the oil has thinned out so much, presumably you are running correct grade?? ie 15/50 or 15/60 etc
Old Apr 21, 2006 | 01:22 PM
Gary F's Avatar
Gary F
Cheers damo fook me i was thinking piston rings engine rebuild all of that im using 15/50 so ya probs right
Old Apr 21, 2006 | 01:37 PM
Damo V's Avatar
Damo V
well it could be rings... you cant discount that... What mileage on engine? any rebuilds?
Old Apr 21, 2006 | 01:38 PM
Gary F's Avatar
Gary F
Dont say that man i was happy its only got 27'000 on the clock
Old Apr 21, 2006 | 01:42 PM
Damo V's Avatar
Damo V
yeah but whats the mileage
Old Apr 21, 2006 | 01:50 PM
Gary F's Avatar
Gary F
that is the millage and its been hpi'd and has the mot's to back it up
Old Apr 21, 2006 | 01:53 PM
Azrael's Avatar
Azrael
Thn turbo failure most probably. Does it let out puff of smoke when changing gear?
Old Apr 21, 2006 | 01:55 PM
Gary F's Avatar
Gary F
No not when changing gear just when the turbos fully boosting the turbos only about 3yr old
Old Apr 21, 2006 | 01:59 PM
Azrael's Avatar
Azrael
That's pretty strange, usually turbos only smoke at full boost when theyt are completly knackered.
Idle? off boost all right too? Cold start? Warm start?
It may be breather problem too. What setup are you running?
Old Apr 21, 2006 | 02:03 PM
Gary F's Avatar
Gary F
I only get the smoke when the turbo is fully boosting thats it none on start up or when i change gear or any thing and the car still feels really strong its stage 3
Old Apr 21, 2006 | 02:09 PM
Azrael's Avatar
Azrael
milkmanif you can actually see it in rear view mirror it's big issue. I wouldn't drive it like that. I would say 99% it's turbo or breather system.
Old Apr 21, 2006 | 02:13 PM
Gary F's Avatar
Gary F
Ok cheers Azreal its getting checked on tuesday so fingers crossed i wont get my pants pulled down
Old Apr 21, 2006 | 02:14 PM
Azrael's Avatar
Azrael
Fingers crossed for you....
Old Apr 21, 2006 | 07:15 PM
Damo V's Avatar
Damo V
Strange 27k car having had a new turbo... at what? 18k miles??
Old Apr 21, 2006 | 09:41 PM
Azrael's Avatar
Azrael
Probably woud require some cold start full boost runs and then hot shut-offs. Still unusuall.
Old Apr 22, 2006 | 11:26 AM
Gary F's Avatar
Gary F
I've got the bill here that says was suggested new turbo as loosing boost
Old Apr 22, 2006 | 11:33 AM
Azrael's Avatar
Azrael
milkman turbo failure rarely comes as boosting problems, usually it starts smoking bvadly, buning oil before any power loss comes
Old Apr 22, 2006 | 11:54 AM
Gary F's Avatar
Gary F
Just what it says on the bill mate, it was long before i owed it
Old Apr 22, 2006 | 01:53 PM
Azrael's Avatar
Azrael
TUrbos can die from long lack of use. I only read about it, never seen one die after long time without engine running but it may be the case.
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
