Small turbo stage 1 chip problems
Old Apr 19, 2006 | 03:14 PM
Escort1.8si's Avatar
Escort1.8si
Default Small turbo stage 1 chip problems
Hello everyone, i have a st escort cosworth with stage 1 superchip and uprated actuator, i havent tried the car without it but i have to say, i dont like the characteristics of the engine at all. It gets way too mutch fuel and sometimes it gives a bang in the exhaust system when i release the throttle. Else if i keep it on gear and release the throttle it will brake like engine is stalling and its really annyoing.
If i drive on slow speed in first gear the car will sometimes bounce forward like its somewhat stalling again i think it might because of the over fueling.
Can i fix this with another aftermarket chip or do i have to put it back to original? Its a Superchip that is fitted
Edit: it also got a kn panel filter and full magnex decat exhaust
Old Apr 19, 2006 | 05:55 PM
Danny-p's Avatar
Danny-p
Default fg
mine was the same mate put it back to standard
Old Apr 19, 2006 | 06:42 PM
cozzymatt's Avatar
cozzymatt
mine was the same on the superchip mate.. I now run a MSD chip and the difference is unreal.. most noticable on the engine braking as you say above...
Matt
Old Apr 19, 2006 | 09:15 PM
Escort1.8si
thanks for reply guys, i might run my orignial then until i eventualy get some real tuning done to it. was thinking about putting megasquirt on it as read in latest fastford and a big turbo and injectors. or just a msd chip
Old Apr 20, 2006 | 01:05 AM
Azrael's Avatar
Azrael
Mine runs just fine on MSD chip, but Superchips wasn't very bad either.
Standard car is undriveble in my opinion. No power whatsoever.
Old Apr 20, 2006 | 08:13 AM
The Youth.'s Avatar
The Youth.
mine has a superchips chip fitted and runs fine, are you sure it isn't something else thats at fault?
steve
Old Apr 20, 2006 | 08:52 AM
Rocco's Avatar
Rocco
i also had/have 1 of superchips chip’s & it made my car cut out or run like a bad of shit so they’ve sent me a new 1 but iv not got round to testing yet
as it took soooooooooooooo long for them to send it
Old Apr 20, 2006 | 07:45 PM
ajjames's Avatar
ajjames
have you got a dump valve fitted to it?
Old Apr 20, 2006 | 09:06 PM
cahzz's Avatar
cahzz
small turbos and sneeze valves dont mix
Old Apr 20, 2006 | 09:16 PM
Escort1.8si
yeah my car has a dump valve fitted and it really makes a high sound compared to another guy around here with a large turbo his dosnt blow halfway as mutch as mine does at only 2500 rpm 2nd gear.
will it dump false air and thats the reason engine is over fueling?
its fitted on cold side just before throttle, so i guess it makes sence the air entering the turbo is registered at the maf and then it is dumped out of the dumpvalve and overfueling.
Old Apr 20, 2006 | 10:28 PM
Robski's Avatar
Robski
ive had a collins dump valve on mine(the one that bolts straight to the turbo) and the car has never missed a beat....it drives faultlessly.Maybe it depends on which dumpvalve and where u locate it?
Old Apr 20, 2006 | 10:52 PM
The Youth.'s Avatar
The Youth.
ditto and mine is fine
steve
Old Apr 20, 2006 | 11:15 PM
Azrael's Avatar
Azrael
Mine used to have weird runing problems. Was dirty ECU multiplug and failed VSS. Now engine runs fine even with dumpvalve (Bailey one)
Old Apr 22, 2006 | 07:53 AM
Escort1.8si
thanks for replys guys,
i might change my dumpvalve then or buy another chip , might be my maf tho witch is from a transit, but it should be the same one.
Old Apr 22, 2006 | 08:23 AM
cahzz's Avatar
cahzz
can someone post a pic of the collins valve in situe please id be intrested to see this product
Old Apr 22, 2006 | 09:14 AM
sailorbob's Avatar
sailorbob
On eec-iv ecu'd cars if the dump valve is after the MAF sensor the dump valve must be of the recirculating type or the engine won't be getting all the air the MAF sensor is reading and fuelling will be off.
I'd also be surprised if a Transit MAF sensor is the same as the small turbo Escort sensor, even if they may look the same but the calibrations are likely to be different.
Old Apr 22, 2006 | 09:16 AM
Azrael's Avatar
Azrael
Still some cars with twn piston or similar dump valves drive just fine.
Old Apr 22, 2006 | 09:22 AM
sailorbob's Avatar
sailorbob
A testament to the level of detail Ford go into for dealing with failure management
Old Apr 22, 2006 | 09:25 AM
Azrael's Avatar
Azrael
I wouldn't be so optimistic about failure managment on small turbo Escos. No "check engine" light, no idling procedure for VSS failure.... etc.
All kinds of MAF equipped turbo cars run just fine with proper dump valves. Imprezas run justfine, Evos sometimes have problems.
On my Escos only effect is that it spits flames from time to time
Old Apr 22, 2006 | 09:42 AM
sailorbob's Avatar
sailorbob
The engine check light code is in the ecu it's just that someone in their wisdom chose not to use it And yes, a VSS failure isn't handled well, it doesn't appear that a MPH_SENSOR_FAILED_FLAG check is carried out by the desired idle calculation routine.
big_Rad
Sep 15, 2017 09:36 AM
3i Jim
Nov 20, 2015 05:12 AM
JasonPD
21
Aug 20, 2015 07:36 PM
IAN RS2k
Aug 18, 2015 07:51 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
