low comp
Old Apr 14, 2006 | 03:16 PM
K500BHP's Avatar
K500BHP
Default low comp
is low comp reqired for 400bhp yb or can you run this ok with standard compor will the
Old Apr 14, 2006 | 03:20 PM
rapidcossie's Avatar
rapidcossie
can be done mate but not really recommended...
Old Apr 14, 2006 | 05:22 PM
GARETH T's Avatar
GARETH T
there is many route too 400 BHP on a yb
one if standard compression,, t4, with the right head and cams, you will be knocking the 400 door
Old Apr 14, 2006 | 05:55 PM
K500BHP's Avatar
K500BHP
t 34 and greys at the mo but got the greys with a view to getting 400bhp still on the standard cams though
Old Apr 14, 2006 | 05:59 PM
Staffi's Avatar
Staffi
400 on a T34, is close to the limits........
Old Apr 14, 2006 | 07:43 PM
K500BHP's Avatar
K500BHP
no more than 400 wanted as its a daily driver i would settle for 380
Old Apr 14, 2006 | 07:44 PM
Staffi's Avatar
Staffi
sounds good to me, similar to mine
Old Apr 14, 2006 | 07:50 PM
K500BHP's Avatar
K500BHP
so it is achievable and still have reliability have you had any probs staffi
Old Apr 14, 2006 | 08:01 PM
Jim Green's Avatar
Jim Green
Mmmmm, I had 370bhp on a T4 with Greys.......with all the right ancillaries, standard cams and head. Not my favorite though, but that was just me, and a T4 which didn't seem as responsive as others that Karl has done. To get a genuine 400bhp on a standard engine you need to use alot of boost 2bar at least, so you really need a very good head gasket, and a strong low milage engine............In my opinion.
370BHP Ish would be more likely, and that's enough for most.
Old Apr 14, 2006 | 08:07 PM
Rick's Avatar
Rick
380hp - one of stu's closed loop setups running blacks. t34, std head and cams, 36psi. weapon
Old Apr 14, 2006 | 08:08 PM
K500BHP's Avatar
K500BHP
like i said 380 would do me and the engine will have a full cometic gasket set and i might get the head worked a little bit as well
Old Apr 14, 2006 | 08:23 PM
Rick's Avatar
Rick
head work will help
Old Apr 14, 2006 | 08:42 PM
Staffi's Avatar
Staffi
Mines been fine, but mine isn`t 400, its 370 Karl as done a fantastic job, as Jim says 370-380 is more than enough.... get yourself to a good mapper, get it setup, and you want believe how good 370 feels when its done properly
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Tank Mike
Sep 26, 2015 08:07 AM
Karl @ FPT
Sep 21, 2015 11:17 AM
