PLEASE PLEASE NEED HELP ASAP
Can some one please sell me a god set of 300mm front brake disks and brake pads for a racing puma set up,
got a track day on weds
They can reface your discs if they are scored or have a lip and not worn to minimum. There are several different compound of pad available IIRC.
Just went out in my ka and the pulsing i was getting back through the pedal was unreal, and on heavy breaking the hole car vibrated.
Would puma speed be able to get them to my house for tuesday though ??
The discs would have to go in the post special delivery 9am on sat am to ensure they got there. That all depends on what the Post office have decided for delivery deadlines over the easter weekend.
You could always get them delivered to brands if your really desperate and fit them on the day then just use your first session driving easy to bed them in.
ive just read that my alcon calipers dont have any form of dust seals, could a piston be sized, would that cause what i am getting ??
Ideally you should take the pads out every month or so and clean all the muck off the pistons.
The damage occurs if you don't remove the muck then push pistons in when putting in new pads for example.
Well ive just stripped front brakes, all 8 pistons move freely, refaced brake pads, copper slipped all touching faces,
went out on rd test prob still there
Just shakes badly when braking above 15- 20 mph
Might aswell try and get a set of discs
ill phone puma build tomorrow and see what decent disc and pad sets they sell
Then pop in on monday on way back from oulton park
Oh and ignore the above - just realised you'd be on 4 stud pattern too
Be pointless spending lots of cash on it until you have found out why they are warping the discs, it will only do the same to the new ones...
Fudgey
Jul 21, 2004 10:11 PM
