Sensor damaged? Help wanted
Old Apr 14, 2006 | 01:29 PM
cozzie4d's Avatar
cozzie4d
Default Sensor damaged? Help wanted
Strange problem (or not):
Saff 2wd, stuttering while accelarating (mainly in 1st and 2nd gear), no problems at all while constantly driving. After much stuttering in 1st and 2nd gear, it won't start anymore. 10 minutes later it starts, and stutters on. Also when pressing the clutch paddle, the revs are jumping.
Any idea, maybe a bad sensor?
Old Apr 14, 2006 | 01:34 PM
K500BHP's Avatar
K500BHP
try the water temp sender (blue one at the back of the head under the inlet manifold i got one from the local parts place for a fiver and quered mine)also is this from when you start the car from cold
Old Apr 14, 2006 | 02:37 PM
cozzie4d's Avatar
cozzie4d
Thanks jim
would be the blue one near the dipstick I think (in the pic). Will try it out.
Old Apr 14, 2006 | 03:26 PM
K500BHP's Avatar
K500BHP
yup thats the one that went on me pain in the arse when started from cold
Old Apr 14, 2006 | 03:27 PM
Alvyn's Avatar
Alvyn
I'd go with the phase sensor in the dissy is knackered
Old Apr 14, 2006 | 03:30 PM
K500BHP's Avatar
K500BHP
good call
Old Apr 14, 2006 | 04:52 PM
cozzie4d's Avatar
cozzie4d
Is the phase sensor the same blue one?
(starting from cold isn't a problem by the way, starting from warm is)
Old Apr 14, 2006 | 04:58 PM
K500BHP's Avatar
K500BHP
no the phase sensor is inside the dizzy the blue sensor is the water temp sensor(i'd try this first )
Old Apr 14, 2006 | 05:09 PM
Alvyn's Avatar
Alvyn
[quote="cozzie4d"]Is the phase sensor the same blue one?
IS it black smoke out the back? which is a sign the coolant temp may be faulty!
but from your problem I'd say the phase sensor(located in the distributor) wires have maybe corroded or it's not adjusted correctly also check the crank pulley sensor ISN'T dirty or even incorrectly adjusted(both the latter will cause ur rev counter to jump around)!
ps HAS THIS JUST STARTED TO HAPPEN?
Old Apr 14, 2006 | 06:43 PM
cozzie4d's Avatar
cozzie4d
It has just started to happen because the engine is put together last week The distributor wasn't used for about 16 months...
I don't see black smoke, although the fact that waiting 10 minutes makes it possible to start, makes it look like it has to do with temperature.
(order to check: blue temp sensor, clean crankshaft-pulley sensor, phase sensor in the distributor)
How about the throttle position sensor?
Old Apr 15, 2006 | 11:20 AM
cozzie4d's Avatar
cozzie4d
Diagnosis update
Just found out that the stuttering/problem isn't there at all when the engine's cold (about 1st 8miles or so).
Maybe more leads to a bad (blue) temp sensor...
Old Apr 16, 2006 | 01:09 PM
Alvyn's Avatar
Alvyn
may be a case of simply having the wrong spark plugs also OR just a case of having it set up correctly as it's a new engine etc!
Old Apr 16, 2006 | 01:14 PM
andre_k's Avatar
andre_k
yup
Old Apr 16, 2006 | 01:33 PM
cozzie4d's Avatar
cozzie4d
Okay.. I understand..
What specific things would you be thinking of, when talking about "setting up" (yep, it is a new engine )
Old Apr 16, 2006 | 01:37 PM
Alvyn's Avatar
Alvyn
What specific things would you be thinking of, when talking about "setting up" (yep, it is a new engine )[/quote]
all down to what spec the engine IS?
different range of spark plugs,fuel pressure the list can go on tbh
Old Apr 17, 2006 | 08:17 AM
cozzie4d's Avatar
cozzie4d
Clear, I'll take that in mind when I visit the engine builder this week.
Who's probably also gonna try if renewing the sensor(s) will help.
Thanks again mate
Old Apr 21, 2006 | 03:04 PM
cozzie4d's Avatar
cozzie4d
Problem solved today..
Cleaned/checked a few ground cables, changed the map sensor AND the most import thing: the crankshaft position sensor (BDP) should be 0.6mm from the "tooth" of the crankshaft pulley. It was somewhere around 4mm, so correcting this probably solved the problem..
Thanks all for the help.
Old Apr 21, 2006 | 06:49 PM
Alvyn's Avatar
Alvyn
glad it's all sorted result m8
moesin2005
Jan 23, 2022 06:28 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
muz
Aug 16, 2015 12:57 PM
dal3door
Aug 13, 2015 06:55 AM
adriansaleem
Aug 3, 2015 11:21 AM
