Have I bought a duff Group A Coil?
Old Apr 13, 2006 | 10:19 AM
TurboShed's Avatar
TurboShed
Cossiemodo
Default Have I bought a duff Group A Coil?
On a Stg 3 Cossie 4x4, I had misfires on boost, and slightly on startup when cold. Bought a Group A coil and fitted it and the misfires were gone, but after about only 10 miles driving I was back where I started, with misfire and total power loss around 4k RPM.
Could the coil have failed that quickly? Or what else might be going on?
NB I tried new plugs and leads too but that made no difference.
Old Apr 13, 2006 | 10:22 AM
Daveyboy's Avatar
Daveyboy
plugs gapped properly?
Old Apr 13, 2006 | 10:24 AM
mk2rstaff's Avatar
mk2rstaff
check all your ht and lt wiring mate, if not that then could be one of your sensors shutting it down to protect the engine, get it plugged in at a diagnostic tester mate
Smit's Avatar
Smit
The 60ft Launch King
Ign Amp earth?
Old Apr 13, 2006 | 11:08 AM
TurboShed's Avatar
TurboShed
Cossiemodo
071's at 0.6
TurboShed's Avatar
TurboShed
Cossiemodo
Originally Posted by Smit
Ign Amp earth?
Cheers, will check that.
Old Apr 13, 2006 | 12:50 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Can't see it being anything being intentionally shut down, as the misfire will result in a huge backfire if I don't lift off the throttle, so it's dumping plenty of fuel in, just it can't get it alight.
jessie_rs
62
Aug 6, 2019 09:27 PM
155lee
Oct 27, 2015 04:55 AM
beller
Sep 21, 2015 04:13 AM
davidfox280585
Shows & Track Days
Sep 17, 2015 10:09 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
