Rounded Sump Plug - Zetec 1.8
Old Apr 13, 2006 | 09:24 AM
robbyridz's Avatar
robbyridz
Default Rounded Sump Plug - Zetec 1.8
Got a day off today, want to do a couple of general maintenance tasks to me escort, oil & filter change have been on my list but I just haven't got round to sorting it
The sump plug is quite rounded and tight, and I can't get it off any ideas to get em off? I'll replace it with a new one when it's off!
Old Apr 13, 2006 | 04:44 PM
CosRush's Avatar
CosRush
Well it depends on what lengths you've gone to and want to go to...
Im guessing you've tried mole grips etc and had no luck?
Has it got any of the Nut body shape left or have all corners rounded off?
If some are left, get an impact Hex socket (the socket is the same shape and the plug head) this might help get it off.
Worse case scenario, tack a small length of steel rod/bar to the sump plug such that it creates a lever, then undo the plug........
Good luck
Old Apr 13, 2006 | 05:17 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
get a flat punch and hit the edge of the sump screw
knock it anti clockwise as the shocking from hitting it will loosing it up too as soon as it starts to move get a set of molegrips on it so u dont damage the threads
Old Apr 13, 2006 | 07:22 PM
nistec's Avatar
nistec
go to machine mart and buy a round nut extractor
something similar to this but containing the correct size or try halfrauds
http://www.machinemart.co.uk/product.asp?p=040214678
Old Apr 13, 2006 | 07:25 PM
nistec's Avatar
nistec
http://www.machinemart.co.uk/product.asp?p=040219960
those are also really handy, i have a set in my tool box at work coz your gaurenteed to round a 15yr old screw off at some point
i also have stud extractors, bolt extractors as well as thread cleaners an tap and die set, all snap on
nothing beats be, ill remove ANY bolt with the gear i have
Old Apr 13, 2006 | 07:26 PM
nistec's Avatar
nistec
http://www.machinemart.co.uk/product.asp?p=040214679
heres the expansion set, so get the one with the size/sizes you need
well worth the money, my set was over Ł100 but earned its money in the first day on a tprx head bolt that sheered off
Old Apr 14, 2006 | 09:24 PM
mercury grey minter's Avatar
mercury grey minter
Go to your local garage and ask them to mig weld another nut onto your rounded off one.Bung them a fiver and go home and undo the nuts that are welded together.Will be the best fiver you,ve ever spent.
Old Apr 15, 2006 | 08:42 AM
HORNETS7's Avatar
HORNETS7
or file two straight edges off the nut and remove with an adjustable spanner!
Old Apr 16, 2006 | 03:18 PM
robbyridz's Avatar
robbyridz
robbyridz's Avatar
robbyridz
if that fails... will try some of these other techniques/ possibly buy some equiptment for future
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
stevierob
Sep 7, 2015 07:09 PM
oilman
Trader Parts for Sale.
Sep 4, 2015 09:34 AM
hopper350
Sep 4, 2015 12:53 AM
cossirob
Sep 3, 2015 09:17 PM
