Bad Idle with 071's
Old Apr 13, 2006 | 02:54 AM
Cosworth-PT's Avatar
Cosworth-PT
Default Bad Idle with 071's
My stage 1 2wd idle speed is unstable with 071's. it keeps making "small" acelerations with a 100 to 200 rpm deviation. any ideas?
Old Apr 13, 2006 | 04:16 AM
snow*'s Avatar
snow*
What have you gapped them to mate?.
From what I can remember....
0.70mm will give you a smoother idle but may be a little lumpy higher up the rev range.
And 0.55mm-0.65mm will be slightly rougher on idle but perform better higher up the rev range.
Old Apr 13, 2006 | 01:46 PM
Cosworth-PT
From what I've seen they (ford dealer) have installed them as they come, I mean didn't see them check the gap, removed each from the motorcraft box and pluged them I will have them out tonight and check
Old Apr 13, 2006 | 04:44 PM
KSA-Cossie's Avatar
KSA-Cossie
As ollie said check the gap m8,mine are gapped at 0.7mm.
Old Apr 14, 2006 | 08:11 AM
cossie604's Avatar
cossie604
gap them at a 45degree angle as well m8 as the earth electrod is very short if you gap them as per normal it wil be too large a gap. Im sure 1 of the nice people on here will have a diagram to post up for you
Stu.
Old Apr 14, 2006 | 09:18 AM
KSA-Cossie's Avatar
KSA-Cossie
Old Apr 14, 2006 | 09:28 PM
cossie604's Avatar
cossie604
^^^^ There you go.....aint passionford mint at being full of helpfull people
fordrallycar
Sep 30, 2015 07:57 PM
Fordmad!
Sep 29, 2015 07:03 PM
A.t.p
Sep 29, 2015 05:04 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
