cossie brake upgrade for rs turbo
where can i get brackets to move std calipers out to take cossie discs?also which discs do you use?2wd or 4x4
this is on a escort rs turbo
cheers
cheers
Originally Posted by Alvyn
may fit straight on m8 if NOT a 1mm washer is all thats needed when using 4x4 calipers and 2 w/d discs
Mike Rainbow does the brackets. Also, you need 2wd discs AFAIK.
what point I know he wanted parts for a rst
as I said what's the point of that mod better of putting 4x4 calipers and 2 w/d discs which WILL improve the braking
what gains does the cossie caliper have over the rs turbo one?[/quote]
the caliper and brake pads are bigger than standard rst's and will cover more if not all of the 2 w/d disks IIRC!
but I'm sure some one WILL correct me
ok,
keeping std calipers you need 2wd cossie discs + mike rainbirds brackets.
going cossie discs + calipers you need 4x4 calipers + 2wd discs.
the first option is actually pretty good, the second is better.
if you have good condition s2 calipers i would probably go that route, but if they need recon'nig then go 4x4 calipers
Mad for it also do the brackets.
Ive been told or read somewhere that using the S2 callipers with brackets and 2wd discs gives more breaking force than using the 4x4 calliper and 2wd disc, dont know how much truth is in it though
Ive got 4x4 calliper and 2wd disc setup on my S2 with Ferodo pads and it works a treat
jason_nike
Aug 18, 2019 10:53 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Red_bull
Aug 9, 2015 08:34 AM
