Car keeps popping indicator fuses
Old Apr 12, 2006 | 04:19 PM
Jim Galbally's Avatar
Jim Galbally
Default Car keeps popping indicator fuses
it did 2x 10s thismorning, and just did a 15 now, they wont last 5 minutes.
thoughts?
Old Apr 12, 2006 | 04:20 PM
Physio's Avatar
Physio
Instead of trying to fit a higher rated fuse why dont you try & find the fault Jimbo?
Are the rear lights shorting out?
Old Apr 12, 2006 | 04:21 PM
MAD EVO 4's Avatar
MAD EVO 4
Must be a short some where on the indicator circuit
Old Apr 12, 2006 | 04:24 PM
Jim Galbally
AJ, i only had a 15 spare thats why
short somewhere on the indicator circuit, shit how on earth do i find that
Old Apr 12, 2006 | 04:27 PM
MAD EVO 4's Avatar
MAD EVO 4
When you put the new engine in did you catch any wiring bro ???
Old Apr 12, 2006 | 04:28 PM
Jim Galbally
fuck knows, i was in bed when it went in
Old Apr 12, 2006 | 04:31 PM
MAD EVO 4's Avatar
MAD EVO 4
Best is to go and check all the wiring looms for any nicks, make sure all connectors are clean and fitted properly
Old Apr 12, 2006 | 04:47 PM
Fil's Avatar
Fil
ELASTIC BAND
i know what that one is, curse of the 24V
check down near your passenger side manifold, theres a cable in some plastic tubeing, bet its melted on the manifold
Old Apr 12, 2006 | 04:48 PM
Oranoco's Avatar
Oranoco
It thinks it's a BMW now and doesn't need indicators
Old Apr 12, 2006 | 04:52 PM
cossie4is dad's Avatar
cossie4is dad
What else is going to go wrong for you Jim ?
You just ain't having any luck.
Steve.
Old Apr 12, 2006 | 04:53 PM
Adrian's Avatar
Adrian
Old Apr 12, 2006 | 06:13 PM
Jim Galbally
i can't find anything obviously amiss down there, altho it is all a bit of a mess.
found out why my oil warning light dont work tho, lol, wire goes to nowhere
Old Apr 12, 2006 | 06:18 PM
Disabled Account's Avatar
Disabled Account
Jim,
Check the reverse light switch on the gearbox and the wires going to it.
If it is like the Es Cos oen then it could be trapped/shorting to earth.....this would give you the problem you have as it's on the same fuse as the indicators and reverse lights.
Old Apr 12, 2006 | 06:38 PM
dojj's Avatar
dojj
Resident Wrestling Legend
as above
unplug the loom for the reversing lihgts (behind the coil pack and it's going to have either 3 or 5 wires in an 8 wire multi plug) and it should solve the problem for the short term
as for the oil light, the wire should plug halfway down into the block on the passenger side front just below the first exhaust manifold pipe
Old Apr 12, 2006 | 06:50 PM
Jim Galbally
oil light's never worked...
doug/dojj... the reversing light is deffo a likely culprit, as thats been fiddled with in the engine swap, and its even routed a funny way.
i'll unplug it for now
Old Apr 12, 2006 | 06:51 PM
EIL132's Avatar
EIL132
DONT put in a bigger fuse. Mates car caught fire because of this
RIB1122
Aug 12, 2015 08:51 PM
xr_craig
Aug 7, 2015 06:00 PM
dlwarrior
Aug 5, 2015 10:19 AM
sjssms
Aug 2, 2015 07:01 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
