cosworth alloy bottom pullys
Old Apr 12, 2006 | 10:21 AM
abdr500's Avatar
abdr500
Default cosworth alloy bottom pullys
cosworth alloy bottom pullys for a 2wd that main pully with the pick up lugs is this a problem it being alloy as i was thinking of a pully set all made from alloy
Old Apr 12, 2006 | 10:53 AM
the original's Avatar
the original
try it again with punctuation?
if you mean the 4 lugs, alloy won't work, they need to be ferrous, the way A1 rally do theirs is to use 4 grub screws screwed into the ally at the appropriate places
some places use an alloy pulley attached to a metal back-plate with the lugs on..
Old Apr 13, 2006 | 06:37 PM
abdr500's Avatar
abdr500
so if i was to use one thats all made of alloy it wount run. as ther is one for sale on ebay and the bloke says he had it running on his car
Bosch
Aug 23, 2015 12:31 PM
borboyous
Aug 22, 2015 11:17 AM
john_3.0s
Aug 15, 2015 07:44 AM
Aug 14, 2015 07:29 AM
lockie
Jul 31, 2015 10:03 PM
