Zoo Motorsport Lower Arms
Hi all, I am keeping my Mk6 escort for a while as working things out we could not afford to run a cossie if anything went wrong e.g. engine we would be stuffed
I was looking at the lower arms by Zoo, as the ford one's dont seem to last on modified cars the worst one being this below were rust get's between the joints and just breaks
Not mine, but this had a MOT a week before this happened with no sign of it going
So as I am keeping my car I was looking at the Zoo ones and they look alot more solid.
http://www.zoomotorsport.co.uk/
Is the one above the "Front tubular wishbones - adjustable camber"? Also is it worth paying the extra £40 for "Rose jointed bottom ball joint to Front tubular wishbone kit"? and are Mk5 lower arms the same as Mk6
Also are these easy to set up? as it would be my local machanic that would be fitting them if I got them
Cheers for any info/advice
Steve
Steve
Steve
Steve
If you get those you will need the bottom ball joint kit.
I think the 5/6 is the same yes.
Fitting would be simple, but would be best checked over and set by someone with a laser alignment gague. Any decent tyre place should have equipment to do that.
HTH
Steve
Steve
HTH
Originally Posted by sooty1977
thats shite the way ur old one's gone
the scary part being is it rusted from the inside out so he didnt see anything untill the bugger snapped And yes I do think the Zoo one looks great aswell
Originally Posted by Bodge22
How much are these? I want some
FIESTA Mk3>, ESCORT Mk5>, PUMA, KA Parts
Front tubular wishbones - adjustable camber £300
Front tubular wishbones - adjustable camber & castor £330
Add Rose jointed bottom ball joint to Front tubular wishbone kit £40
Rose jointed rear beam (Fiesta Only) £175
Thanks mate
I'm seriously thinking about it, imean you don't want the ford part snapping do you!!!!!!!!!!
Well that's what i'll tell the wife anyway
thats what I told my wife aswell
Thanks mate
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
