valve stem oil seals
Old Apr 11, 2006 | 08:06 PM
sufsRS's Avatar
sufsRS
Default valve stem oil seals
in the process of doing valve stem oil seals when taking the old ones out how do i put new ones in do i have to really push down on them, havnt quite got a socket big enough to tap them in, any more tips too
Old Apr 11, 2006 | 08:16 PM
infinityMJD's Avatar
infinityMJD
urm, ok deffo stem seals u mean???
Thats the little gromit type bit that goes around the valve stem at the top of the head, you just compress the valve and remove collets, remove spring and top cap, slide old off and slide new on, depending on engine (ive only done cvh) its a rubber grommit with little spring round it, just pops in then rebuild valve assembly and go on to next!
Old Apr 11, 2006 | 09:36 PM
SafeChav's Avatar
SafeChav
You should be able to push them on with your fingers they're not that tight. What valve springs are you running? The modified stem seals are far better!!
Old Apr 11, 2006 | 10:20 PM
biglee's Avatar
biglee
Audio specialist
i allways use the ford revised version, they are mega never ever let me down, the top hat type that sit under the spring and they just pop on there, no force needed!
Old Apr 11, 2006 | 10:24 PM
SafeChav's Avatar
SafeChav
I agree but they are useless if you run double valve springs.......
Old Apr 11, 2006 | 10:26 PM
biglee's Avatar
biglee
Audio specialist
why is that? i have double springs on mine and its cool as?
Old Apr 11, 2006 | 10:29 PM
SafeChav's Avatar
SafeChav
The springs sit very badly with the top hat style, you're not meant to use them, double springs sit badly on the head with normal stem seals alone. You can buy some adapter washers to sort it all out but you can't run the modified seals alone. Next time (IF) you have a valve spring off look at how the inside spring sits on the top hat.......
Old Apr 11, 2006 | 10:39 PM
biglee's Avatar
biglee
Audio specialist
mine sit perfectly around the little angled bit, i know what your getting at both springs sit right on the deck, not the smaller spring sitting half way up the angled bit like ive seen before.
Old Apr 11, 2006 | 10:40 PM
SafeChav's Avatar
SafeChav
Even with the little raised bit on the top hat ones they don't sit too clever
CVH top ends are just shit full stop
Old Apr 11, 2006 | 10:47 PM
biglee's Avatar
biglee
Audio specialist
agreed but they are cheap lol
Old Apr 11, 2006 | 10:49 PM
infinityMJD
a m8 said something about steal stem seals from an orion or something??? was a long time ago now and dont realy remember but he was a total ford nut so just wonderd if any of you had heard of them, all the cvh ones ive used are rubber
Old Apr 11, 2006 | 10:51 PM
SafeChav's Avatar
SafeChav
biglee: I hear you
One and the same thing mate, probably talkng about the top hat ones, the rubber ones were standard and are pants
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
krypton
Sep 23, 2015 07:29 PM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
hopper350
Sep 4, 2015 12:53 AM
