Any one got pin out's L6 2wd ECU ?
Old Apr 11, 2006 | 06:02 PM
Doug's Avatar
Doug
Default Any one got pin out's L6 2wd ECU ?
Has any one got the pin out's in a diagram as i need to wire a component in and need to know where to take the RPM signal from .
Regards Doug .
Old Apr 11, 2006 | 06:15 PM
Graceland's Avatar
Graceland
Team HOTHOT!
pin 26 for the rpm signal - but double check this Doug
Old Apr 11, 2006 | 06:17 PM
Guinnless's Avatar
Guinnless
pin outs
pin 1 earth
pin 19 earth
pin 2 lambda sensor
pin 20 positive power feed
pin 3 crank pos sensor
pin 21 not used
pin 4 crank position sensor
pin 22 knock sensor
pin 5 distributor connection
pin 23 distributor connection
pin 6 knock sensor with earth bonding sheild
pin 24 ignition module pin 3
pin 7 canister purge valve
pin 25 ign module pin 6
pin 8 electronic control loom
pin 26 not used
pin 9 linked to pin 30 (MAP and throttle pos)
pin 27 electronic control loom
pin 10 EFI power delay relay in fuse box
pin 28 fuel pump relay
pin 11 map sensor
pin 29 coolant temp sensor
pin 12 not used
pin 30 map sensor and throttle pos sensor
pin 13 octane adjust
pin 31 air charge temp
pin 14 octane adjust
pin 32 injector 2
pin 15 map sensor
pin 33 injector 3
pin 16 boost control valve
pin 34 idle speed control valve
pin 17 throttle pos sensor
pin 35 injector 1
pin 18 injector 4
Old Apr 11, 2006 | 06:19 PM
Stu @ M Developments's Avatar
PassionFords Creator
Pin 25 is an ignition trigger output to the ignition module Doug.
Old Apr 11, 2006 | 06:28 PM
Doug's Avatar
Doug
Thank you very much guy's
Old Apr 11, 2006 | 07:20 PM
JjCoDeX75's Avatar
JjCoDeX75
I take it that the Apexi has arrived?
JJ
Old Apr 11, 2006 | 07:41 PM
Doug's Avatar
Doug
Yes JJ this morning my threatening e-mail to him on friday must have worked
Last week he said he had sent it with DHL so why did it arive with royal mail gauranteed next day
What a W*nker
Least its here
And She is in
Regards Doug
Old Apr 11, 2006 | 07:56 PM
Graceland's Avatar
Graceland
Team HOTHOT!
I was one pin out
Pin 26 must be used in conjunction with the coilpack driver then
Old Apr 11, 2006 | 08:03 PM
I was one pin out
Correct.
Old Apr 11, 2006 | 10:25 PM
JjCoDeX75's Avatar
JjCoDeX75
What a W*nker
Least its here
And She is in
Regards Doug
Glad to hear that it has finally arrived!
Post whether or not you got the speed sensor thing to work, and let me know if you think it was worth the effort. Also, I have emailed you a complete schematic for the L1 (and L6) ECU!
JJ
JJ
Old Apr 11, 2006 | 10:40 PM
Doug's Avatar
Doug
What a W*nker
Least its here
And She is in
Regards Doug
JJ
JJ
Will do mate
DixieTheKid
11
Jun 6, 2020 11:20 AM
mark r
Sep 29, 2015 07:27 PM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
