Best supplier for cam cover gaskets etc?
Apr 11, 2006 | 03:01 PM
As title peeps. Changing the belt etc, need a new cam cover gasket and half moon seals etc. Ford want ££££ for them.
Anyone?
Apr 11, 2006 | 03:03 PM
woodford garage. i use the cometic one as its reusable.
Apr 11, 2006 | 03:05 PM
From: learnin to build a yb lump properly in dennis's garage
spooky burtons have em on the shelf at 18 quid just phoned em 10 mins ago for my car
Apr 11, 2006 | 03:10 PM
Deffo get a Cometic 1
Wouldn't bother with the standard one
Apr 11, 2006 | 03:13 PM
are they worth it what makes the cometic so good?
Apr 11, 2006 | 03:15 PM
Quote:
you can reuse it - many many times, and it doesn't nead any sealer as its an expanding foam gasket
Apr 11, 2006 | 03:17 PM
with a steel cener i think, the standard ones are pants, they rip every time
how much are they as im gonna need one also
Apr 11, 2006 | 03:20 PM
i fink about £25
Apr 11, 2006 | 03:21 PM
Matt Lewis is your man
Apr 11, 2006 | 03:24 PM
RS & ST Parts Specialists
Cheers Paul
Plynchy............ parts will be with you by tomorrow that you ordered
Regards Matt
Re: Best supplier for cam cover gaskets etc?
Quote:
Anyone?
you have pm
Apr 11, 2006 | 03:30 PM
Apr 11, 2006 | 03:42 PM
Quote:
Originally Posted by Matt Lewis
Cheers Paul
Regards Matt
Cheers Matt.
Never thought to order the gaskets off you as well, muppet.
Thanks for the info lads!
Apr 12, 2006 | 07:38 AM
definitely go with a cometic.
i recently also got a rubber one off ebay that seems to be quite good and re-usable. i'll see how it holds up to some ring abuse.
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
