One for the techies!!!
Old Apr 11, 2006 | 06:46 AM
RsDarren's Avatar
RsDarren
From: Dewsbury, The parts were they don't abduct their own children!
Default One for the techies!!!
Having problems with my frst. built it back up last weekend, started it up last night and it runs great one minute then rubbish the next!
It sounds like the fuel isn't getting through, but then it does the next minute?
Could it be the fuels regulator or maybe a loose wire??
It's not been moved for 11 months could it be just sh*t in the tank???
Any help appreitiated???
Darren
Old Apr 11, 2006 | 07:44 AM
jrs's Avatar
jrs
I wouldn't mess about with the fueling. Could be the idle speed controler or the crank position sensor does the car smoke when driving?
Old Apr 11, 2006 | 08:38 AM
Brookesy's Avatar
Brookesy
With regards to the fuel, petrol seperates after a couple of months so if its been stood for a long time you could have crap in the fuel lines and the filter
Old Apr 11, 2006 | 10:44 AM
jrs's Avatar
jrs
I seen the throttle position sensor play up and make the car run bady you can get one of the failt code readers on ebay for around Ł17
Old Apr 11, 2006 | 10:59 AM
DUDE_SWEET_FRST's Avatar
DUDE_SWEET_FRST
yeah not a good idea using 11 month old fuel.
empty the tank and fuel lines
Old Apr 11, 2006 | 11:33 AM
RsDarren's Avatar
RsDarren
Thanks lads,
Have put a jerry cans worth of new petrol but might have to put some more in?
No the car does'nt smoke when driving, it also gets a bit better when the car warms up????
All i did was take the fuel pipe off to see if it was pumping to the injectors, your right don't want to mess with fueling.
I'll check these out tonight thanks lads, will keep you updated!!
Daz
Old Apr 12, 2006 | 07:29 AM
RsDarren's Avatar
RsDarren
After a long night of removing every little electrical connection, checking them and little blast of wd40 and re-connectiong. Removing and emptying the fuel tank/lines, Ł20's worth of optimax and crossed fingers she is running like a dream!!!
Thanks for all your help and suggestions
Bring on Mototrsport Developments for a set up!!
Bring on the Summer!!!
Old Apr 12, 2006 | 08:45 AM
jrs's Avatar
jrs
So what do you think it was?
Old Apr 12, 2006 | 03:51 PM
RsDarren's Avatar
RsDarren
Not to sure probably the petrol? i did all the work then turned her over and it worked.
But wont of done it any harm to check all the electical connections??
Old Apr 12, 2006 | 04:50 PM
DUDE_SWEET_FRST
well i can say that my 7 month old fuel deteriorated, and it was at fault for it not starting it was sparking, and fueling, but it wasnt igniting
so putting new fuel back in will of certainly helped
BigErn
Mar 10, 2008 08:15 AM
Red16
58
Jul 31, 2007 02:07 PM
SapphyMike
Jun 14, 2007 09:08 AM
cabrio zo
12
Mar 21, 2007 03:52 PM
Cola
122
Jul 27, 2005 04:25 PM
