RST-GEARBOX QUESTION.........
Old Apr 10, 2006 | 10:55 PM
COSSIE 1's Avatar
COSSIE 1
Default RST-GEARBOX QUESTION.........
Hi guys i was driving along in my s2rst the other day i put it into 5th gear and about 10 seconds later in suddenly popped out of gear?? the gearbox has been fully rebuilt only about 2k miles ago the gearbox doesnt whine and all gears are easy to find but one thing i have noticed the throw is very long. could this problem be where i didnt push it right into gear and it just popped out??, cheers all.
Old Apr 11, 2006 | 07:38 PM
nistec's Avatar
nistec
im also keen to know the answer to this
Old Apr 11, 2006 | 07:47 PM
Shings's Avatar
Shings
Poorly built box in my opinion.
I had my RST box go so I got a rebuild and it did this straight away, took it back and they replaced the selector and 5th gear and it lasted 200 miles.
Just got myself a 2nd hand box that hadn't been touched.
I must have expected too much for my 150 quid.
If I ever have another RST I will without hesitation have one of CTS (Bernie/Gearboxmans) Stg 1 boxes at the very least.
Jake
Old Apr 11, 2006 | 07:49 PM
nistec's Avatar
nistec
cheers mate
im buying this car off paul you see
ill strip and rebuild the box myself if i have to or send it to the company we use who are the bollocks
Old Apr 11, 2006 | 10:47 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Could easily be a badly adjusted linkage IMO......
Old Apr 12, 2006 | 06:55 AM
gingeRS's Avatar
gingeRS
Jake
how long ago was this, what happened when it failed after 200 miles?
Worn syncro is the answer, just not a good gearbox build
bernie/gearboxman he's the man when it comes to rst boxes
Old Apr 12, 2006 | 07:41 AM
ballin's Avatar
ballin
rebuilt box's are wank.
Old Apr 12, 2006 | 08:20 AM
gingeRS's Avatar
gingeRS
constructive
on what engineering theory do you base that on?????
Old Apr 12, 2006 | 08:24 AM
ballin's Avatar
ballin
none.
more due to the fact, of the 2 I have had both have been absolute junk (one failed after a few K and the second jumps out of gear in 1st & 2nd)....and never heard anything good about rebuilds either. (barring one or two companies)
cts box or original ford is the only ones i would ever buy now
Old Apr 12, 2006 | 08:52 AM
John Laverick's Avatar
John Laverick
none.
A CTS box is a rebuild
I've had a re-built box in the past which was Very good and lasted a good few years running high power.
Obviously the two you had were cheap & nasty re-con boxes
Old Apr 12, 2006 | 09:43 AM
ballin's Avatar
ballin
and no they werent actually, its quite common
Old Apr 12, 2006 | 10:36 AM
gingeRS's Avatar
gingeRS
none.
re-con re-build.......its all the same thing
in the many years of breaking boxes with RST's there are a few chunks of vital information you must know when buying a gearbox.
1. A rebuilt box should ALWAYS have a new shaft in it
2. Larger or uprated bearings require the casing to be modded, not the shaft.
3. If you have any doubts about any components, bin them, and replace with new.
4. Dont trust any gearbox builder who machines the shaft, or claims anything about sleeving the shaft for 'strength'
5. A DIESEL GEARBOX IS NOT STRONGER THAN AN RST BOX!
hope this helps. havent had a rant about boxes in ages, and belive me, i have destroyed a few.
Old Apr 12, 2006 | 05:04 PM
Shings's Avatar
Shings
none.
Afirmative.
Bernies boxes might also be rebuilds BUT they seem to be generally pretty good and I certainly wouldn't entertain anything else.. but thats me...
Ginge, when the box went again I just fucked it off, I couldn't be arsed with the hassle of them fixing it.. BUT I did get em to fit it..
J
Smit
46
Jun 25, 2011 10:24 PM
Physio
12
Jun 25, 2007 05:48 PM
