map sensor
Old Apr 10, 2006 | 12:24 PM
hoyas's Avatar
hoyas
Default map sensor
first time i have to say i´m writeing from spain, so excuse me for the gramatical foults
i´ve a sapphire 4x4, the map sensor have broke. i want to know if i could put on my sapphire the map sensor from a escort t34. bouth are from original cars
thanks fron spain
Old Apr 10, 2006 | 12:33 PM
stonehavencossie's Avatar
stonehavencossie
If your car is standard/stage 1 it will be using a 2 bar map sensor.
Im sure the escos uses a 2.5 bar map sensor ?
If it is stage 3 you will need a replacement 3 bar map sensor
Hope this helps
there is always some on ebay
Old Apr 10, 2006 | 02:32 PM
foreigneRS's Avatar
foreigneRS
Testing the future
as above.
think about it.
a 2 bar MAP sensor gives an output of 5V at 2 bar (1 bar of boost + 1 bar atmosphere).
a 2.5 bar MAP sensor gives an output of 5V at 2.5 bar (1.5 bar of boost + 1 bar atmosphere).
so if you fit the 2.5 bar one, and have 1 bar of boost, the 2.5 bar sensor will only output around 4V, which your ecu will think is only 1.8 bar so not give you enough fuel for that amount of air.
Old Apr 10, 2006 | 08:36 PM
hoyas's Avatar
hoyas
i don´t know why, but in the shop told me if i put on my car any other map which isn´t the original, y could broke the engine. not bigger map, or other cars map. but i don´t understand why.
here, original map cost 200 euros, arround 140 pounds, i have been lookin on ebay, but there are only 3 bar maps. i haven´t see originals.
thanks for your help
Old Apr 10, 2006 | 10:30 PM
CosRush's Avatar
CosRush
I have an original 2 bar for sale in the 'For Sale' section on here..........
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
