3 door missfire
Old Apr 10, 2006 | 12:16 PM
Harris.'s Avatar
Harris.
Default 3 door missfire
Just seeing if anyone can help or has the same problem, My cossie has a misfire!!! Now ive changed the leads,plugs,rota arm and ive also changed the phase sensor as the old one was nakered!!! I still have the missfire and ive also got aload of black crap comming out the exhaust,the cars running stage 1 ,i have been told its over fueling would this cause the misfire if so how do you set the fueling up or can anyone recomend the best place to take the car too in essex ??
Any help would be great
Old Apr 10, 2006 | 02:28 PM
Staffi's Avatar
Staffi
Sounds like a live map needed to me if you can travel then NMS i`d say but there also Mark Shead MA DEVELOPMENTS
Old Apr 10, 2006 | 07:35 PM
Harris.'s Avatar
Harris.
My wallets going to be empty again, god i love having a cossie
Old Apr 10, 2006 | 09:08 PM
Harris.'s Avatar
Harris.
Anyone know how much a live map is?
Old Apr 10, 2006 | 09:27 PM
Staffi's Avatar
Staffi
You have PM dave..........
Old Apr 10, 2006 | 09:30 PM
Harris.'s Avatar
Harris.
So do you
Old Apr 10, 2006 | 10:05 PM
jon@work's Avatar
jon@work
Coolant Temp Sensor Checking - info courtesy of Simon @ SECS
1) Ensure ignition is OFF.
2) Remove rear of ecu plug cover and insert plug back into ecu.
3) Turn ignition back on (do not start engine)
4) Check resistance between pins 29 and 11. Should be 800 to 5000 ohms (depends on temp). If outside this range, check sensor and/or wiring.
Old Apr 11, 2006 | 12:54 PM
Harris.'s Avatar
Harris.
Ok m8 i will give it ago ,its a level 6 ecu in my 3 door
Old Apr 11, 2006 | 04:00 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
a mate fixed a 3dr that was running poorly,he used to do work for RED and anyway he did something to the crank sensor and cured it,the car had had leads plugs dizzy and then a rebuild,sensor cost nothing and took 5 mins,car dealer who owned the car was
Old Apr 11, 2006 | 09:48 PM
cossie350's Avatar
cossie350
I had the same problem with my 3dr changed everything you listed above but it turned out to be the ignition amplifier.......
Old Apr 16, 2006 | 04:11 PM
Harris.'s Avatar
Harris.
Ive got in booked in for mapping next sat, £350 is this a good price as i dont really understand all this mapping stuff tbh what it involves etc???
Old Apr 17, 2006 | 02:46 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
i would get it running ok before spending 350notes on that
chowfornow
14
Jan 5, 2019 09:01 PM
mpilk
Sep 27, 2015 09:21 AM
Vacuman
Sep 22, 2015 12:09 PM
Vincereese
Sep 18, 2015 12:48 PM
