Cosworth 200 Bottom-End (wire-rung)
Old Apr 10, 2006 | 11:10 AM
silky16v's Avatar
silky16v
Get on That!
Default Cosworth 200 Bottom-End (wire-rung)
RS Cosworth 200 Block (Wire-Rung) fully rebuilt 1850 mile ago
I have reciepts for all work done and for all parts
work included re-bore of block to 0.5mm over-size
All main bearing tunnels were checked and measured & face of block aswell
300 mile old Standard Crank & Rods used when rebuilt (standard grind)
the crank was polished and balanced
Brand new 0.5mm Standard Mahle Pistons
WRC High Pressure Spec Oil Pump & WRC Spec Water Pump from (msport)
Brand New Ford Bearing Fitted Mains & Big-Ends
ARP Big-End Bolts
Machined Flat 4x4 Flywheel & New Bolts Fitted
Also comes with PAS Pump & Alternator & 4x4 Sump fitted & 4x4 Distributor
Engine was removed from my 4x4 1993 Saph due 2 it being written off (not my fault ) And had only just been Stage 3 setup from STU@MSD (360bhp)
Engine is in perfect condition & is ready to be fitted & can be viewed at anytime
Collection Prefered
£1400 O.N.O
Please Pm or Call me on: 07743448179
Old Apr 11, 2006 | 07:06 PM
silky16v's Avatar
silky16v
Get on That!
upski
Nov 3, 2015 04:08 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Rsmat
63
Sep 25, 2015 12:11 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
