GRP A Head Bolts & Gasket.
Old Apr 7, 2006 | 04:09 PM
WD Pro's Avatar
WD Pro
Default GRP A Head Bolts & Gasket.
Hi Guys how much boost is safe on GRP A head bolts & gasket when clamped to an RS500 bolck (7.2CR) ?
And based on the max boost from the above what approx power 'could' the engine make with correctly speced injectors, turbo, map etc ? For info the cams are standard and the head is ported and polished.
Thanks in advance for any replies / guidance.
WD
Old Apr 7, 2006 | 04:18 PM
Damo V's Avatar
Damo V
what turbo
Old Apr 7, 2006 | 04:25 PM
WD Pro's Avatar
WD Pro
Dont know yet !
Just want to know what it could handle 'If' pushed hard and what would be 'safe' on that gasket / head / block configuration.
Cheers,
WD
Old Apr 7, 2006 | 04:28 PM
Damo V's Avatar
Damo V
depends on the turbo tiny turbos dont force as much air through as HUGE ones
Old Apr 7, 2006 | 04:30 PM
WD Pro's Avatar
WD Pro
Been thinking of / advised GT30 or similar.
WD
PS : Got to go off line soon so dont think I am blanking you, thanks for the interest.
Old Apr 7, 2006 | 04:36 PM
big_wig_074's Avatar
big_wig_074
get a proper metal gasket,then run as much as you like!
Old Apr 7, 2006 | 04:38 PM
Damo V's Avatar
Damo V
proper WRC 4 layer steel gasket, do not pass go do not collect 200 quid, dont mess around with silly cheap gaskets
Old Apr 7, 2006 | 07:34 PM
WD Pro's Avatar
WD Pro
I know the WRC gasket seems the way to go but what will it handle now ?
I dont want to rebuild if nessasary, will the head need a skim if it comes off or is it just a case of swaping gaskets and then re-torquing ? How will the WRC gasket work with the Grp A bolts or does it need long studding ?
Cheers,
WD
Old Apr 7, 2006 | 07:57 PM
Damo V's Avatar
Damo V
Needs longstudding in theory though some have run before without, head and block need to be perfectly flat.
Dont expect a std HG (read Group A) to last very long if you are running say 1.5-2 bar on that turbo IMO
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
IainRS1700T
Sep 25, 2015 06:44 AM
focuspower
Sep 19, 2015 08:27 PM
hopper350
Sep 4, 2015 12:53 AM
