Brickwork.....Cutting a BIG hole!!
We need to cut 2 circular holes of around 650mm diameter through a brick/block wall.
Any idea's how this can easily be done?
Originally Posted by Jonzy
As damo said use a drill
. Mark up your hole on the block work then drill lotsa holes like an outline. Then chop the hole out with a bolster.
I know that Diamond core drills exist in this kind of size, but where to get one? Even if we have to pay someone to come and do it.
Originally Posted by GARETH T
i would chain drill it aswell
if you did get a core dril for that size,,, the drilling machine will be large,, and i would hate to see it snatch
Would be more of a body breaker than a wrist breaker eh
i was doing a 9" hole with a core drill a few years ago,,, massive drilling machine,, and it nipped in the wall,,, chucked me clean off the ladder and my wrist was fucked for weeks
Originally Posted by Snowy_Astra
What i wanna know is what in the hell demands not one, but TWO 650mm holes in a wall?!
Still, won't need a lintel or support as its a load bearing shape
We figured the same, that if we cut a circular hole, it won't need a lintel.
So, it looks like it's going to be hard graft then?
Anyone want to come and do it in exchange for a RR tune??!!
Originally Posted by morch
An 11kw fan, jesus man. I shouldn,t want to stand to close to it at full chat.
I take it it is 3 phase, and has star- delta start up?
LOL. Yes it is 3-phase. We have just bought a Danfoss Inverter to run it, giving us full speed control, I imagine that might be a little on the powerful side for your bog standard Citroen Saxo's.
See how that compares to what you see tomorrow!!
as all ready said mate chain drill it it wont take long and as for a core 650mm well that will take a big drill to turn that and if you can find a firm that can do it, it will probley cost quite a bit as i wont be a drill that you hold it will be on a frame / stand.
I dont think you will have to worry about straping the cars down, the puff from that beast should hold em back!!!!!
You may have to book me in for a tune up soon as i had a dissapointing day on sunday
The less said the better.
The less said the better.We had the fan running at the weekend. The Speed Controller has a digital display and we saw 19.4hp from it!!!
SMILER258
Sep 28, 2015 09:04 AM
