help needed plz some 1
Old Apr 6, 2006 | 06:05 PM
scort_si's Avatar
scort_si
Default help needed plz some 1
the pipe on my back box that joins the middle section has snaped from the box
the help i need is there an easy way to pull the pipe of tried wd40 hammer and flat end
screwdriver but cant seem to get the back box pipe off,cant take to my local garage because
ive tried 3 and they say they only suply and fit there own goods so need to get this pipe off
asap!!!
Old Apr 6, 2006 | 07:32 PM
CosKev3's Avatar
CosKev3
The easiest way I've found is to cut a slice in it with an angle grinder,goin at it steady though so you don't cut through pipe inside
Otherwise a sharp chisel will slice through it pretty easy
Old Apr 9, 2006 | 12:51 AM
cossie350's Avatar
cossie350
Heat it up till its really fucking hot with some oxycetilene (spelling) if you can get your hands on some then welt it a good un
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
