Best Cossie Breather for Stage 3 + Cossie
Say a Cossie running a T34 and greens/greys, what is the best oil breather kit, and where from?
Also can you explain if its worth it taking a feed from the cam cover, and whether certian kits allow this.
I've been told ideally I'd want 2 inlets and 2 outlets, then the outlets will go under the bottom of the car to keep bad smells out
https://passionford.com/forum/viewtopic.php?t=182653
https://passionford.com/forum/viewtopic.php?t=134768
Plenty to read there, and plenty of answers.
Doh! Too slow
Doh! Too slow
Originally Posted by Stu @ M Developments
Whilst i can see what your saying, i feel that the concept of 30mm input area requires 30mm output area is very simple and thus its very easy to see with the untrained eye that LOTS of systems dont cater for this most basic of requirements.
Mine:
Mine:
So in Stu's setup, he has it breathing from the fire trap and the cam cover, then what? As you can't see any others as they're out of view
This is my breather set up, does the same job just mine has an extra outlet on the pot with goes to the catch tank.
Cheers guys
From what I can see then, the mirror image and the breather tanks do the same thing?
So as long as I have a large breather pot OR a mirror image tank, with 4 large ports, inlets going to fire trap and cam cover, and outlets going to return to the sump and one venting to atmosphere i'll be ok?
Cheers guys
But surely in Stu's there is:
Breathing from the fire trap and the cam cover
and There is another 2 outlets under the breather. 1 is going to atmosphere & the other is returning to the sump.
So there is still only one return to the sump
Not sure to be honest.. I would imagine that stu has his breathing from both sides of the block and not using the blanked block breather as the return. But i could be wrong as Stu's spec isnt huge is it..
The Bailey one is perfectly adequate - the key is how it is set up. Ideally, you want it breathing from the flame trap and then point underneath the exhaust manifold (side of the block). The return the goes to the SUMP. If you have it connected in the way that Bailey suggest (for ease of fitting - which is breathing from flame trap, cam cover and then draining to side fitting under exhaust manifold), then the only time that the oil can return to the engine is when it is switched off, as the crank-case pressure will otherwise prevent it from doing so (which is why you have to have the oil return back to below oil level in the sump).
Obviously, this requires a fitting being welded in the sump, which is then the ideal time for a big-wing item
That is temporary, as the WRC one is soon to be fitted, and you won't even be able to tell it has one on the car
yeah i know dave, seen one fitted to Spadges old 500 engine, no denying it fits well.
But if i remember it comes at a premium price does it? i.e £300-400? before fittings?
So about £500.
Saything that, think mine was about that new.
So about £500.
PassionFords Creator
Mc5506
Oct 5, 2015 09:57 PM
