nearly there.. but :cry:
Old Apr 6, 2006 | 05:21 PM
pee vee's Avatar
pee vee
Default nearly there.. but :cry:
Nearly back together again!!
BUT..
Engineers just rang about the cylinder head,
everything perfect. except 2 slightly bent Exhaust valves
£40 EACH valve from everywhere!!!!
car always went well..
so it should go Really good when its run in again!!
Old Apr 6, 2006 | 05:36 PM
rapidcossie's Avatar
rapidcossie
yeah getting close mate
Old Apr 6, 2006 | 06:10 PM
KSA-Cossie's Avatar
KSA-Cossie
Not long to go m8.
Old Apr 6, 2006 | 07:04 PM
pee vee's Avatar
pee vee
the exhaust valves must of only been very very slightly bent.
not quite seating properly or something
as i didnt notice it with the head off. and the car didnt mis-fire or anything
like that..
odd. but i guess it will all be good as new when its done!!
things done aareeee
(top down lol)
cam bearings
stem seals
valve guides
2 new valves
Grp A H/Gasket
4 new 0.5mm mhale pistons
new little ends
new water pump
cam belt and tensioner
engine mounts
bottom end bearings
crank polish (in perfect condition )
new cosworth oil pump
oil pump drive
AP clutch
every gasket and seal in the engine replaced
block refaced (3 thou)
head refaced (3 thou)
Flywheel re-faced
everything (engine block, spray bar etc)
chemically cleaned/de-greased
everything else shot blasted to clean it
Diff casing
sump
engine mounting arms
new oil pressure gauge
new oil temp gauge
And its only been off the road a month itching to get it back and
run it in!!
Old Apr 6, 2006 | 07:07 PM
JamesH's Avatar
JamesH
It is well worth it in the end mate
Old Apr 6, 2006 | 07:09 PM
pee vee's Avatar
pee vee
yeah, only realising now that the sun is begninning to show,
how much i enjoy having it!
love it when its looking all shiney and mint,
not even having to go quick but just driving about in it,
i guess cos its just something not quite every-day
to have.
Old Apr 6, 2006 | 07:14 PM
TurboShed's Avatar
TurboShed
Cossiemodo
What kind of £££ are you looking at for all that work??
Old Apr 6, 2006 | 07:21 PM
pee vee's Avatar
pee vee
dont ask that lol
ummm.
err i dunno i didnt like to count or add up really.
ive been gathering the parts for a while (6 months)
i guess 2-3 grand for a rebuild like this?
give or take lol
depends on what sort of parts you go for on your rebuild mate to be honest
Old Apr 8, 2006 | 03:01 PM
pee vee's Avatar
pee vee
got the head back!
soo i spent an hour or two doin this!
I HATE doing head bolts up!! Especially checking that they are all done to
110 NM... horrid feeling thinking they are gonna rip the fookin threads out
Old Apr 8, 2006 | 08:36 PM
pee vee's Avatar
pee vee
one more
Old Apr 9, 2006 | 08:30 PM
CosKev3's Avatar
CosKev3
110NM
Thats way to much m8
My Cosworth manual says stage 1 25NM,stage 2 50NM,stage 3 170 to 180 degrees
Old Apr 9, 2006 | 08:33 PM
pee vee's Avatar
pee vee
the ford manual says
50NM
then 180 degrees
then
'check for 110 NM'
so after the 180 degrees bit they are very close to it anyway?
mine were
Old Apr 9, 2006 | 08:54 PM
CosKev3's Avatar
CosKev3
Could have changed there wording between manuals,mines a 2wd Cosworth manual
Old Apr 9, 2006 | 08:58 PM
CosKev3's Avatar
CosKev3
Just looked in my 4x4 Cosworth workshop manual,says same as I posted before
Found the page you were lookin at,page I looked at is 21-8,wierd they list two different sequences
Then again it is Ford
Old Apr 10, 2006 | 03:48 PM
pee vee's Avatar
pee vee
strange isnt it??
Alrthough,, the Early 2wd head bolts were different wernt they,
so perhaps there is a different sequence for that???
Although the way i did it deffo was for the 90 spec 200 block engine, as
you can see at the bottom of the page...
strange! but If you left them all at 180 degrees, thats no
guarantee that they are all the same tightness? as some differences in metal??
so making them all to 110 NM is to ensure even torque??
as a side note, i looked Also in a normal sierra manual, and they say
to do the 2ltr pinto head bolts to 115NM!!!
Old Apr 10, 2006 | 04:06 PM
deleted's Avatar
deleted
From: learnin to build a yb lump properly in dennis's garage
alwayus was a mint car looks good mate
Old Apr 10, 2006 | 04:13 PM
pee vee's Avatar
pee vee
thanks Grant! (your name is Grant isnt it )
Old Apr 10, 2006 | 04:15 PM
deleted's Avatar
deleted
yep it is
turbochild
13
Oct 1, 2015 05:33 AM
Fil
Sep 30, 2015 12:08 PM
Fiddy
21
Sep 29, 2015 06:10 PM
gcfcos
24
Sep 21, 2015 04:26 PM
