fuel pump residuel pressure valve....do you need it?
Old Apr 6, 2006 | 06:00 AM
M K's Avatar
M K
Default fuel pump residuel pressure valve....do you need it?
as above,,
its not in a cossie its in my mk2 xr2.....
but im running a group A 044fuel pump & full aeroquip set up/braided lines throughout,
i was gonna fit a straight adapter to both ends of the fuel pump then add a straight/90 or a 45 whichever is needed as it looks better than a straight 1 end & banjo the other
but this means removing the pressure valve thats screwed in to 1 end
will this make difference???
i was told it keeps pressure in the pump to ease starting but will the priming when you turn the ignition not do this anyway?
hope you get what i mean
Old Apr 6, 2006 | 11:13 AM
rsnissan's Avatar
rsnissan
other than the priming it will mean the car wont leak petrol out of the pump unless its on.
i.e an acident or if you roll the bastid. I kept mine on there and just used a banjo and the cap
Old Apr 6, 2006 | 11:43 AM
SafeChav's Avatar
SafeChav
If you took it out you would soon regret it, expecially when trying to do a hot start, plus the fact it will rape the pump
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
