urgent help pls guys!!!
Old Apr 5, 2006 | 06:56 PM
drunkennosh's Avatar
drunkennosh
Default urgent help pls guys!!!
guys im stuck, just changed my upper grille on my 04 plate focus for new one, put all screws back where i found them pushed the bonnet down to lock and click! it locks it just dont unlock anymore!!!!! then i found a little screw, now i remember that i think this one came from the top of the bonnet lock. now im confused on how ford wiould have a little screw working the lock!!!!!
i have a foci that i can open the bonnet. the lock is not moving!!!
any ideas!!!
Old Apr 5, 2006 | 06:58 PM
SPADGE's Avatar
SPADGE
You sure you havn't trapped a tool or something on the slam panel thus putting pressure on the bonnet forcing it against the lock? Try pushing down slightly around the lock area on the bonnet and try the lock at the same time.
Old Apr 5, 2006 | 06:59 PM
drunkennosh
still dont unlock even with my fat bum leaning on it.... the actual lock dont move .... and all tools accounted for...
Old Apr 5, 2006 | 07:02 PM
SPADGE's Avatar
SPADGE
Don't know then mate
Can your remove the grill with the bonnet shut to access the lock?
Old Apr 5, 2006 | 07:07 PM
drunkennosh
no mate, the grille is held on behind the grille itself and you need the boeent open to reach this places, its made of metal so cant even think of a way around it.
Old Apr 5, 2006 | 07:13 PM
Damo V's Avatar
Damo V
You need one of these
Old Apr 5, 2006 | 07:39 PM
drunkennosh
good news!!!!! me dad fixed it!!!! simple when i thought about. ..
the thickness of the powder coated steel didnt let the key go fully into the lock...
method - lean on grille
result key went in far enough and hey presto lock unlocked!!!!
Old Apr 5, 2006 | 07:42 PM
graham c's Avatar
graham c
is the screw a little philps it gose at the top of the bonnet lock should hold grille if all else fails you can undo yours rads on tnhe black rail an then undo the 2 ten mills that hold your lock on then look y your bonnet wont open
`spotty
Sep 25, 2015 11:41 PM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
martynhomer01
14
Sep 23, 2015 12:23 AM
davidfordrs
Sep 21, 2015 04:23 AM
Rizlablue
Sep 6, 2015 09:58 AM
