how do you sort the revs on an RS Turbo?
Just started the RS for the first time in 6 months or more (more i think)
however it sits at 2k revs how do you set it so it sits at under 1k?
wait till its warm and the chokes off mate then if u look at the bottom of the throttle body above the in let manifold there'll be a large screw/bolt screwing into the throtle body , im pretty sure u screw it in to drop the revs and out to put them up. But motor must be warm
Dont do it on the throttle cable
Matt Baxter
Sep 16, 2015 08:30 PM
cozzy jeff
Aug 14, 2015 05:46 PM
