4x4 engine into a 3 door(CAR WILL BE 2WD ENGINES OUT OF 4B)
Originally Posted by cossiecrew
i know i have to change the sump but what else needs changing ?
you need to change the thermostate housing
umm, cant think of anything else off hand!
which loom and ecu are you using? the TPS are not directly compatible
transfer oer the hwole front end
you'll need the suspension, shocks and struts as well as the tca's and crossmember as well as the rack and the intermidiate shaft
basicly, undo the top mounts from inside the engine bay
undo the crossmember from the chassis rails
get the abs pump etc out tooundo the gearbox x member
and the arb mounts
pull the prop mount off too
undo the prop from the diff
everything slides underneath the 3 door
a bit of jigger pokery with the gearbox mounts and it's all done
you will also need to bodge about with the loom for the abs as the 4wd abs does different hings to the 2wd abs so brain across too
thats about it
for those of you who know what diff ratios there are, you might also need to swap the rear diff over too, but that means the whole lot of the rear axle as the 3 door has a 7.5 inch diff while the 4x4 has a 7 inch diff, and no you can't just wap the diff over as the driveshafts and cv's won't fit into the 7 inch from the 7.5 as the bigger one uses a 108pcd while the 4wd uses a 100 mm pcd
and the arb mounts
thats about it
rog
Sep 4, 2015 12:10 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
lockie
Jul 31, 2015 10:03 PM
