Rear crankshaft oil seal replacement
Old Apr 5, 2006 | 01:26 PM
SPADGE's Avatar
SPADGE
Default Rear crankshaft oil seal replacement
I am currently rebuilding my bottom end and am trying to fit a new rear seal
If i put it in before tightening the rear mains cap it gets pushed out on tightening!
How do you fit it once the crank is in?
Cheers Spadge...
Old Apr 5, 2006 | 01:28 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
the seal comes with a plastic sheild which helps to fit it.
Old Apr 5, 2006 | 01:40 PM
SPADGE's Avatar
SPADGE
A bit more info please
I have no plastic shield so what exactly are you meant to do with it and why the smiley
Old Apr 5, 2006 | 01:55 PM
Ryan's Avatar
Ryan
yeah the seal i got from fords had some plastic shelid round it, fook knows how your supposed to fit it though, havent got round to it yet
Old Apr 5, 2006 | 01:57 PM
DaveEscos's Avatar
DaveEscos
Old Apr 5, 2006 | 02:05 PM
foreigneRS's Avatar
foreigneRS
Testing the future
or you butt the old one up to it backwards and use that to tap it in
Old Apr 5, 2006 | 02:06 PM
Stu @ M Developments's Avatar
PassionFords Creator
Just slide it over the end of the crank and tap it home spadge, easy job M8.
Old Apr 5, 2006 | 02:09 PM
SPADGE's Avatar
SPADGE
Thanks Stu and and Nick
I thought that might be the case but didn't want to do it and find i shouldn't have!
Old Apr 5, 2006 | 02:48 PM
bud-weis's Avatar
bud-weis
Football Cwazy
i fitted mine after the mains were fitted,just slides over the crank and then i tapped it gently but firmly ( if you get what i mean ) whilst continuously moving around the circumference of it ( so you don't push one side in too much at a time)
Old Apr 5, 2006 | 02:59 PM
rsnissan's Avatar
rsnissan
i just used a pipe the same diameter and taped it home squarely with a rubber mallet after everything else was done
Old Apr 5, 2006 | 03:48 PM
JTECH James
Passion for Fords!
The plastic sheild is there to stop the inside of the sheild catching the crank, you place it over the crank end and slide the seal in, then remove the plastic jobby, and tap it home with either the old seal, or somin soft.
The was because people always throw the plastic jobbie away
Old Apr 5, 2006 | 03:50 PM
JTECH James
Passion for Fords!
When i say sheild i mean the inner part of the seal, which can get damaged when pushing it over the crank, i have seen people use a screwdriver to get it over.......
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Danielbetty
Aug 28, 2015 08:01 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
st220kyle
16
Aug 14, 2015 06:13 AM
Bosch
Aug 4, 2015 05:14 PM
