cam timing on a series2 engine
Old Apr 4, 2006 | 08:05 PM
Mattie_M's Avatar
Mattie_M
Default cam timing on a series2 engine
ive got a mk.1 xr2 and i have fitted a piper cam kit to the series2 head but the vernier pulley has to timin marks, can any1 help me???? i no the crank is set at 12 in no.1 piston is set at t.d.c, cheerz
Old Apr 4, 2006 | 08:10 PM
Rick's Avatar
Rick
you have to find out what the crank position should be when no 1 inlet is at full lift, by measuring it with a DTI
Old Apr 4, 2006 | 10:24 PM
HORNETS7's Avatar
HORNETS7
the crank pulley should be at tdc
and the cam pulley at tdc
the ignition timing fires at 12degrees before tdc !
Old Apr 4, 2006 | 10:25 PM
SafeChav's Avatar
SafeChav
IIRC when timed up properly the cam's wood-ruff key should be at 6 o'clock.
JoeyBoyden
Jan 4, 2024 02:36 PM
RUBY123
Oct 22, 2023 12:04 PM
Roosie
Aug 13, 2015 07:40 PM
taylora1409
Aug 12, 2015 12:06 PM
Ellsa
Aug 9, 2015 07:03 PM
