Boost/Actuator question
Old Apr 4, 2006 | 07:50 PM
Daveyboy's Avatar
Daveyboy
Default Boost/Actuator question
Trying to set the boost on stage 1 saph. set the preload on it, half moon, that should be about a bar. However, its boosting over 20 and thats only going up to about 4.5rpm before backing off cos its way too much god knows what it would be if i floored it
even if i turn it down more it still boosts the same.
Now, would that be indicative of a fucked actuator? or am i being a pleb?
Old Apr 4, 2006 | 07:54 PM
abdr500's Avatar
abdr500
are the vacuum hoses the right way around on the amal valve unwind the actuator arm if that don't work then I would join the vacuum pipe from the compressor housing to actuator and go from ther to see if the amal valve is at fault
Old Apr 4, 2006 | 07:57 PM
Andreas's Avatar
Andreas
Perhaps the jets on amal valve have already been modified? Its not a mechanical bleedvalve on there either is it?
Old Apr 4, 2006 | 07:58 PM
davidreader5's Avatar
davidreader5
HI,
Or you could disconnect the amal valve, and you should have just
actuator pressure, if so you need to check the amal valve and jets
in it.
Dave R.
Old Apr 4, 2006 | 08:00 PM
Daveyboy's Avatar
Daveyboy
Im 99.9% sure the hoses are right. If it runs properly with the vacuum pipe from compressor housing attached to actuator does that mean the amal valve is faulty then?
thanks
and no, its not got a bleed valve on it.
Old Apr 4, 2006 | 08:03 PM
It doesnt mean its faulty, might just mean its got wrong sized jets.
but thats the place to start, as then you can see what the actuator is set to if you run it straight off the housing
Old Apr 4, 2006 | 08:06 PM
Daveyboy's Avatar
Daveyboy
its the same amal valve ive run on it for ages. cars just been off the road for a while and since its been back ive not been able to set the boost right.
Will give it a go with the amal valve disconnected though
cheers
Old Apr 4, 2006 | 08:16 PM
abdr500's Avatar
abdr500
i was right put a bleed valve on it the brass one with the locking nut on it
Old Apr 4, 2006 | 08:32 PM
ballin's Avatar
ballin
certainly not fucked actuator, the opposite in fact!
Old Apr 4, 2006 | 08:42 PM
wapster's Avatar
wapster
dude the amal did take a nock loop out amal should run same as 3dr did about 8 psi
Old Apr 4, 2006 | 08:45 PM
RichardPON's Avatar
RichardPON
Stick the bleed valvle that I have sat here on it!
Old Apr 4, 2006 | 08:48 PM
SPADGE's Avatar
SPADGE
It amal valve related definatly mate
Either its fooked or you have lost a jet!
Got a few here should you require a replacement
Old Apr 4, 2006 | 08:49 PM
wapster's Avatar
wapster
sorted u da bitch pon
Old Apr 4, 2006 | 10:06 PM
Daveyboy's Avatar
Daveyboy
holds much lower boost now so deffo amal valve as you've all said
cheers Rich & Spadge, i'll let you know
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
