another 4x4/2wd cossie question regarding rear end
Old Apr 4, 2006 | 07:12 PM
cossiecrew's Avatar
cossiecrew
Default another 4x4/2wd cossie question regarding rear end
after the crash im planning to build my 3 door project and if i was to use my rear beam and diff(4x4) will i be able to use 2wd driveshafts and 2wd prop as i want the 3 door as 2wd
Old Apr 4, 2006 | 07:13 PM
cossiecrew's Avatar
cossiecrew
oh forgot to say i will be using 3 door rear arms and rear arb
Old Apr 4, 2006 | 07:26 PM
abdr500's Avatar
abdr500
no the 2wd shaft will not fit the 4x4 diff if you use the 2wd gear box and 2wd prop that will be fine use the 4x4 shaft job done
Old Apr 4, 2006 | 07:34 PM
cossiecrew's Avatar
cossiecrew
thinking about it i knew it wouldnt fit as someone told me that before but i was also told that 4x4 shafts are to skinny and weak for a 2wd
Old Apr 4, 2006 | 07:37 PM
SPADGE's Avatar
SPADGE
Just get a 2wd rear beam and diff mate
There is no point using the 7" 4x4 one!
cossiecrew's Avatar
cossiecrew
think im gonna use the 4x4 shafts and fook it if they snap they snap lol
Old Apr 4, 2006 | 07:38 PM
cossiecrew's Avatar
cossiecrew
spadge aint the 4x4 diff better though im sure i read something a while ago
Old Apr 4, 2006 | 08:54 PM
abdr500's Avatar
abdr500
cossiecrewno the 4x4 are not better but the conversion you are doing is just fine but as said above 2wd complete back end job done no messing around
Old Apr 4, 2006 | 11:05 PM
cossiecrew's Avatar
cossiecrew
think i might see how the 4x4 parts cope then as i already have them sitting here
Old Apr 5, 2006 | 09:57 AM
Jay,'s Avatar
Jay,
Sponsor
mark just fit a 2wd diff ect ull be breakin cv joints ect if u dont , if ur guna build the 3door up then do it right i tight twat
Old Apr 5, 2006 | 04:10 PM
cossiecrew's Avatar
cossiecrew
jessie_rs
11
Jun 3, 2019 04:57 PM
Wilsfoci
15
Mar 30, 2016 10:26 PM
borboyous
Aug 22, 2015 11:17 AM
Caddyshack
Aug 19, 2015 07:29 PM
track.focus'd
Aug 12, 2015 05:53 PM
