Setting up Koni's
Old Apr 4, 2006 | 06:40 PM
Default Setting up Koni's
...ok just bought a second hand set of front koni's (cheers Tabz) i have no idea where they are set...how many position is there and how do i reset set them to number 1 position? I assume that means softest?
Thanks
Old Apr 4, 2006 | 06:51 PM
rapidcossie's Avatar
rapidcossie
fronts=turn them fully clockwise to harden.
will need to get the instructions out to check rear settings but have to be done off the car
Old Apr 4, 2006 | 06:53 PM
rapidcossie
with the rear removed from the car compress them in a vice.
a 180 deg turn clock wise stifens them to first setting.
360 deg turn to middle and a 720 deg turn to full hard
Old Apr 4, 2006 | 06:56 PM
Jim Galbally's Avatar
Jim Galbally
3 settings on rear i think. push and twist
fronts are self explanitory :P
Old Apr 4, 2006 | 06:57 PM
rapidcossie
all the way anti clock wise until they stop to set to full soft to start with then
Old Apr 4, 2006 | 07:00 PM
...cheers Rapid..and bollocks to Jimbo
How many settings on the front?
Old Apr 4, 2006 | 07:01 PM
Jim Galbally
phil, thrun it all the way to the left, then all te way to the right (counting the clicks)
THAT'S HOW MANY SETTINGS THERE ARE
Old Apr 4, 2006 | 07:04 PM
..so you dont know but feel the need to answer
Old Apr 4, 2006 | 10:24 PM
rapidcossie
mines dont click at all
Old Apr 4, 2006 | 10:50 PM
Billabong's Avatar
Billabong
The fronts don't click, well, not the common yellow sports kit. The equivalent of a click is half a turn (180 degrees).
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
cossie330
Sep 27, 2015 04:13 PM
ajamesc
Sep 27, 2015 02:25 PM
lime
Sep 25, 2015 06:56 PM
