do need to own a cossy to get response on this forum
have been on this site several times mostly trying to pick pepoles brains, but it seems unless its about a cossy no 1 cares. any 1 else agree
i dnt have a cossie and normaly get a responce it depends on what your askin and if people no it theres a lot of people on here that only no about cossies and rst some others that no about diffrent things , from what i found people help weere they can
not so much no. ive asked questions about my 1.8 sapphire and i get responces. you generally get more respances about rs's and cossie and such cause they are more common and people are more interested in them
Fook i havent seen this statement in years
SINCE THE RSPASSIONCLUB,....ooops,,....my mistake,...
in my experience, this forum used to be amazing in the early days....
i mean,....AMAZING
now it seems that people reply if they can be arsed,....not if they know,...
the PASSION seems not to be there as it did,......
see what i did there,....passion,....passionford,...
im ere all week
carl
if you get your username changed to *hotsinglesexygirl* you'll get loads of replies whether theyre relevant or not is a different matter.
and no you don't it just depends on what question it is your asking about really..
Originally Posted by TIFF
noone has spoke to me since i sold my 3dr........
and no you don't ... and no i can not answer your questions about arb clamps or will i allow you to sell parts without paying the Ł20 gold mmbership fee .. sorry ...
Originally Posted by graemewelch
you mean i have to be a arse licking gold member to have a opinon or to ask a opinon. am not trying to sell it and just doing some research. whats the point in a forum when not allowed to ask certain questions?
asking bout a mondeo tdci. trying to get hold of a speed sensor. ford are wanting over Ł70 and not sure if it will cure my problem
ok,...first off,...rotate the universal fan-dangle counter clockwise, then scare a koala bear,...but be very careful that it is a koala and not an indian elephant,...next, remove the spoon from the badger, then refit using a small iguana.....that should sort it out,..
same happened on mine,.....works everytime....
that any help,.....see,...i replied....
Originally Posted by John Laverick
I remember back in the RSOC board days this used to be a regular topic at one point.
I've got an RS Turbo but none of the Cosworth boys will talk to me
tbh i have a Petrol mondeo as a day to day driver and i wouldnt expect much of an answer on here if i had a problem with it, as yes most people own cossies/rs's so they know more about them.
Are you registered on the mondeo boards ? http://www.fordmondeo.org/
not asking for a break down on how they work just want to no if any 1 knows wear you can get them cheaper than ford
problem ive got is that i bought a 2002 mondeo tdci with bust engine so fitted engine and box from a 54 plate with 9000mile. on new 6 speed box hasnt got a speed sensor in the gearbox. on 53 plate or newer it uses sensors on all for wheels wear as the 5 speed has a sensor above the drive shft but the 6 speed box has the mounting point above the drive shaft the same as the 5 speed so hoping i can plug sensor in and will work. not sure if will so dont want to spend 80 quid to find out still have no speedo
that is the kind of question that wont often get a response.
i saw the question, and i didnt reply.
why? because i didnt have a fucking CLUE what the answer was
The reason i didnt reply to that is i havent got a fucking clue
[quote="graemewelch"]problem ive got is that i bought a 2002 mondeo tdci with bust engine so fitted engine and box from a 54 plate with 9000mile. on new 6 speed box hasnt got a speed sensor in the gearbox. on 53 plate or newer it uses sensors on all for wheels wear as the 5 speed has a sensor above the drive shft but the 6 speed box has the mounting point above the drive shaft the same as the 5 speed so hoping i can plug sensor in and will work. not sure if will so dont want to spend 80 quid to find out still have no
I doubt anyone on hear knows the answer to that question even now that you have asked it properly
Ask that Tiff geezer he is a fellow Mondo oil burner fan so he may know
So your left with a new dilemer DO U REFIT THE 5 SPEED or do you try and sort the signal issues from the wheel sensor to convert it to the pcm ?
Hope that answeres your question .
Regards Doug .
if you want to try this forum http://www.fordmondeo.org/forum/index.php?
its mainly mondeo owners on there and some very knowledgeable people there too, some of them are members on here also.
