Big power/reving cvh people SORTED
What cam ,springs and lifters are u using cos i cant get mine to rev above 6.2k its got a piper t2 and stronger valve springsin it , its pissin me off a bit now
jamie said was goin to ring newman and see wat they could do with the cam and to stop the valves bouncin, just wonder wat people like tim, oli , tony were usin to stop this
is it not the management choping back the ignition timing? ive got one of those 7200rpm revlimters on my mfi rs, and runnin 285t2, it revs fine al the way
swappin cam soon tho
When you say it wont rev above 6200rpm are you refering to where your power drops off as in its peak power?
or
Your car physicaly wont rev beyond 6200rpm (say for example) like hitting a rev limiter at 6200rpm?
or
Mine is a std cam, and with a t34, full boost at 3600 and so far it's mapped to 6,5k, and wants to rev past no problem. What is actually happening? U shouldnt be getting valve float - are the lifters pumping up?
newman cam with solid lifters then see pumaracing for his double valve spring system you wont suffer valve float until you pass 8000rpm..
what oil is in it? Although solid lifters will cure it, they shouldnt pump up at 6.2. Ivr gone past 7k a few times with no problem. U could try a new set if u dont want to go all out with the newman.
havin a newman cam and kit fitted next week . hopefully will sort it and can rev it to 7.2k-7.5k
change the springs!! have some custom ones made
yes the map can be finished off then , should b done next week
cool, how different does it drive?
JK12
33
Apr 26, 2021 12:09 PM
