xr2i fuel pump damper
Old Apr 4, 2006 | 12:50 PM
Toe Knee's Avatar
Toe Knee
Default xr2i fuel pump damper
After finding out that my 2i running problem was due to 1 of the seals on the pump damper being perished causing loss of fuel pressure i went an ordered another one from ford. Temporarily i bridged the pump/fuel pipe with some fuel hosing to find out if it was that at fault or not and it was hence ordering a new 1 but.................are they actually needed?!?!
I was looking on ebay for pumps as orginally i thought it was that and all the ones i saw on there didnt have the damper but a normal fuel pipe joining them up instead. so....is it even worth having the damper?!?! guessing due to the shape of it stores a small amount of fuel (ie the dome bit) but if it aint needed im left wondering whether to bother with it or not?!?!
Its this bit here, bit worried incase the seals go again, but then guess its taken most of the cars life for it to perish thou....
and this is 1 of the ones that the damper removed and bridged with a pipe on ebay.......
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
