How close would you expect an off the shelf chip to be??
Old Apr 3, 2006 | 09:20 PM
Garage19's Avatar
Garage19
Default How close would you expect an off the shelf chip to be??
I rigged up my LM-1 on a mates cossie the other night only to find it running very rich (8.5:1 afr mostly on boost).
He recently had it setup with an off the shelf chip from a fairly well known tuning company and hasn't changed anything since.
I understand that an off the shelf chip will be set on the safe side so as to cater for the slight variations in specification on different cars but would you expect them to set it soooo rich?
I haven't had much experience of off the shelf chips for cossies so i thought i had better ask?
Stu or Karl, if you knew the spec of a car, how close would you expect to get to optimum fuelling from a chip with out live mapping?
Old Apr 3, 2006 | 09:23 PM
Eagle's Avatar
Eagle
Super Moderator
wouldn't that be down to whoever set the car up ??? ie the fuelling
Old Apr 3, 2006 | 09:34 PM
Garage19's Avatar
Garage19
Chip and setup was from the same company.
Old Apr 3, 2006 | 09:37 PM
Eagle's Avatar
Eagle
Super Moderator
ahh ok ..
Old Apr 3, 2006 | 09:45 PM
bud-weis's Avatar
bud-weis
Football Cwazy
i had an off the shelf chip from Stu, and apart from the known problem i had past 5500rpm, the AFR was 11.5 on boost til then
Even with an off the shelf chip,the setup should have sorted the fuelling much better than that
Old Apr 3, 2006 | 10:11 PM
Stu @ M Developments's Avatar
PassionFords Creator
8.5:1 is madness. I am surprised it burns it ok to be honest and would expect missfires galore.
Old Apr 4, 2006 | 08:23 AM
Garage19's Avatar
Garage19
The car was run on a rr and their wideband showed it running very rich. We double checked with my wideband in the evening and it showed the same results.
So two independant tests showed the same results.
When i went out in it the car didn't feel as urgent as i would have expected.
When the owner contacted the tuner he gave a speel about settining up on the rich side as expected, and that the only way he could really change it is with a live map at a cost of another Ł????.
Would you:
A: Go back and ask him to sort his chip out free of charge
B: Go for the live map and ask him to knock the cost of the chip and the setup of the price of it.
C: Just shell out for the live map.
D: Ask for you money back for the chip and setup and take your business elsewhere?
We could probably get an improvement on the fueling all the way across the range by knocing back the fuel pressure but the car owner is running stock pressure and a set of greys and i am reluctant to do this as i am un sure of the effects on atomisation/spray pattern??
Old Apr 4, 2006 | 08:41 AM
GARETH T's Avatar
GARETH T
E buy a chip from stu
Old Apr 4, 2006 | 08:44 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
They obviously don't know what they are doing, so take it back IMO....
Old Apr 4, 2006 | 08:46 AM
Greys, say no more. 95% of off the shelf greys chips i see are like this, not to mention the 7.2:1 old Cosworth spark map that drives like crap at bottom end
Old Apr 4, 2006 | 08:49 AM
Garage19's Avatar
Garage19
Thats the problem, they are actually quite a well respected tuner with motorsport pedigree.
Thats why at first i thought the RRs wideband sensor may be telling porkies and double checked it with mine!
I was sure they wouldn't have let it go out the door running like that, but apparently they did??? The setup/chip was only done 3 days before the RR day.
Old Apr 4, 2006 | 08:50 AM
Jay,'s Avatar
Jay,
Sponsor
or F for fuck all that and pay stu for a live map
Old Apr 4, 2006 | 08:51 AM
Garage19's Avatar
Garage19
It doesn't idle right either missing all over the shop.
Old Apr 4, 2006 | 09:21 AM
Are you confident the rest of the system is ok though?
Cam timing, air and water sensors, etc etc...
Old Apr 4, 2006 | 11:52 AM
Garage19's Avatar
Garage19
It is not my car so i cannot guarentee these things, however surely the tuner should have noted any probs when working on the car and made the owner aware.
The owner has since contacted the tuner to find out why its is running mostly 8.5:afr on boost. The tuner did not dispute that it was running that rich but said that it was set up like that to be mega safe!!!
Old Apr 4, 2006 | 12:01 PM
Oh well, not a lot more you can say to that really. If thats teh service they intended to offer and they are happy with it, then thats teh service he has bought. Job done.
Old Apr 4, 2006 | 12:07 PM
Garage19's Avatar
Garage19
I know. It seems strange. I expected more of this company
Stu, could you pm me a price of one of your chips if you have anything to suit greys, t34, 7.8cr, rs500 IC. Will get you are more detailed spec if needed.
Old Apr 4, 2006 | 12:34 PM
Done.
Old Apr 4, 2006 | 12:40 PM
8.5:1 is safe now is it?
borewashtastic, not safe at all.
Name and shame the company IMHO
Old Apr 4, 2006 | 12:44 PM
...well my karl off the shelp map wernt too shabby with a little tinkering i am running around 11.5 to 11.9 on boost...and around 13.5 cruising
8.5-1 is mad...bet the fuel consumption aint too special ...be interesting to put my lm1 on the EA off the shelf mapped escos thats on greys.
Old Apr 4, 2006 | 01:13 PM
Garage19's Avatar
Garage19
Dissapointing service, but not really my place to name them on a public forum.
Old Apr 4, 2006 | 01:21 PM
fordsportjay's Avatar
fordsportjay
but youre dying to...............if thats what they offer then maybe people should be forewarned.
Quote fixed by webteam.
Old Apr 4, 2006 | 02:31 PM
Dave Henshall's Avatar
Dave Henshall
are they based in congleton by any chance..?
Old Apr 4, 2006 | 04:38 PM
Eagle's Avatar
Eagle
Super Moderator
got my chip from stu ..set up by MAD .. drives lovely
Old Apr 4, 2006 | 06:26 PM
Garage19's Avatar
Garage19
Where? i dont think so.
Old Apr 5, 2006 | 10:36 AM
Dave Henshall
it snot who i think it is then...
Old Apr 5, 2006 | 11:17 AM
Rick's Avatar
Rick
8.5?!
MY car coughs at 9:1!
Old Apr 5, 2006 | 03:17 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Is this Matts Car ?
Steve.
Old Apr 5, 2006 | 03:55 PM
Gooey's Avatar
Gooey
Originally Posted by cossie4i
Is this Matts Car ?
Steve.
It certainly sounds like it
Old Apr 5, 2006 | 04:52 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Is this Matts Car ?
Steve.
But is it ??????
Steve.
Old Apr 5, 2006 | 10:42 PM
GARETH T's Avatar
GARETH T
i didnt think the LM-1 would measure a/f that rich
Old Apr 6, 2006 | 08:57 AM
Old Apr 6, 2006 | 09:16 AM
Garage19's Avatar
Garage19
Gareth, you are right. It just about managed to measure 8.5:1 and then went into sensor error mode "too rich".
And yes it is Matts car.
tankybaby66
Feb 6, 2016 02:24 PM
Rod-Tarry
75
Oct 13, 2015 04:44 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
