Zetec running problems
Old Apr 3, 2006 | 08:48 PM
Chairman's Avatar
Chairman
Default Zetec running problems
Hello there...
Got a Cabriolet Escort (XR3i) with the 1.8 Zetec engine,
Im having problems getting the engine to run smoothly, it starts straight away but dies immediately, I have found that if i unplug the throttle position sensor then i can coax it into idle, and it revs up fine if done carefully.
it has been stood a long time without use.
Can anyone advise me on what I can check, such as correct voltages etc...?
I know electronics and have test equipment, just not familiar with the cars test points and procedures.
Thanks in advance.
Mark.
Old Apr 3, 2006 | 08:57 PM
Chairman's Avatar
Chairman
Also, just found a Fault code reader i had tucked away, it says it does 1.8 Escorts.... with 3 Pin connector..
Will this be any use?
Cheers.
Old Apr 4, 2006 | 12:07 PM
pen2403's Avatar
pen2403
Default 1.8 zetec
hello mate this is not an awnser its a question!!!
did convert it yourself if so did u change the loom as ive just brought a 1.8 zetec with full wiring loom but dont know where to start with the wiring or where to finish my loom is in about 3/4 different sections and i dont know what parts to fit
Old Apr 4, 2006 | 05:17 PM
Chairman's Avatar
Chairman
No its not a conversion ive had done, its the standard lump in the car... its a MK5 Escort
Old Apr 4, 2006 | 07:39 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
sounds like the idle speed control valve a well known fault on all zetecs
take of and clean with some petrol or replace
hope this helps
Old Apr 6, 2006 | 08:13 PM
Chairman's Avatar
Chairman
Thanks ill try that,
I had one of the ISCV units cause probs on an old xr4x4 I had...
What is inside this unit? will it be visible if its clogged up?
Old Apr 6, 2006 | 10:18 PM
robbyridz's Avatar
robbyridz
Will let you know tommorow morning you may have seen - I'm having the same problem, I'm going to get another one from breakers to try - as the garage seem to think it looks clean - but will see for myself when it's off and in the light
Will let you know
Old Apr 17, 2006 | 03:51 PM
Chairman's Avatar
Chairman
I fixed all my problems..
Turned out to be wires broken at the top of the heater, by the wiper arms..
Looks like a rodent has been chewing them....lol
Old Apr 17, 2006 | 06:10 PM
Old Apr 18, 2006 | 08:07 PM
robbyridz's Avatar
robbyridz
I'd better check all my cables... when the idle got worse, it was coz one of the wires on the connector to me iscv had fallen off
but I'll check those wires tommorow, would be beauts if it's just that - causing my probs!
**DAMN RODENTOS MOMENTOS!!**
loughlin1
Ford Fiesta
Aug 20, 2015 10:42 PM
jaysoc1
Aug 20, 2015 08:18 PM
gingerturbo
Aug 18, 2015 07:58 PM
Zoggon
Aug 10, 2015 10:39 AM
turbobill
Aug 9, 2015 05:21 PM
