Today. I found the perfect loom wrapping material!
And it was cheap as chips, £2.50 a meter!
Its fish pond rubber pipe, we slit it down one side, and pressed the loom into it. I'll get some pics in an hour, deffo worth the money, and makes the engine bay look tidy and mint
Originally Posted by Markb_s1
how is it with regard to heat resistance?
I'll pop a peice in the oven and see when it starts going soft and on fire
http://www.vehicle-wiring-products.c.../sleeving.html
Between 45p and £1.15 per metre for convoluted here.
I also like the look of the braided sleeving in a tidy engine bay.
Its great if you're not taking plugs off, which would seriously hinder the fitting of the pectal braided stuff.
Its got all the properties i'm after, it stays flexible, even with the slit down the side, and when you twist it, the slit stays inline on the both halves keeping the seal.
To hold it to the body work, my mate suggested just putting a self tapper and washer through it into the metal behind to hold it solid to the contour of the bay.
Also looks quite professional, as if its meant for that job. My loom looks brand new, and i'm dead chuffed
Not bad what you can do for under a tenner
Originally Posted by richj
I hate to burst your bubble, but if you go into a electrical wholesaler and ask for Adaptaflex you'll get the same stuff for about 60c a meter (about 40p in sterling)
I work for an electrical contractor and we use it the whole time. No problem getting it.
http://www.adaptaflex.co.uk/
None of the shops round here have it, and another thing i found with the larger size conduit, is that it kinks up in tight bends and ultimately looks shit lol
I'm dead chuffed with the stuff i got now anyway, its glossy + shiney, clean, bends well, can screw it to the panels, etc
Cheers for the info though
JK12
33
Apr 26, 2021 12:09 PM
Adam Graham
Sep 6, 2015 06:04 AM
