4x4 cossie various bits left
Old Mar 31, 2006 | 07:26 PM
butterfly's Avatar
butterfly
Default 4x4 cossie various bits left
I HAVE SOME BITS LEFT OVER FROM BREAKING MY 4X4 COSSIE.
PARTS FOR SALE DO NOT INC POSTAGE.
FRONT DIFF GOOD COND SOLD
REAR DIFF GOOD CON SOLD
MASTER CYCLINDER £25.00
ABS UNIT & BRACKET £25.00
BOSCH HEADLIGHTS VGC £40.00
OIL PUMP & PICKUP PIPE £25.00
ADJUSTABLE STEERING COLUMN WITH LOCK £25.00
STEERING COUPLING £20.00
KIDNEY BOX £10.00
CLUTCH CABLE £10.00
SPEEDO CABLE £10.00
FRONT CROSS MEMBER £25.00
PLATE BETWEEN ENGINE AND GEAR BOX £15.00
SCORPION DOWN PIPE SLIGHT SCUFF SOLD
REAR PROP SHAFT SOLD
HT LEADS & DIST CAP £15.00
LIGHTENED FLYWHEEL £40.00
FRONT TRACK CONTROL ARMS £15.00
HEATED SCREEN LOOM & RELAYS £25.00
ANTI ROLL BAR (FRONT) £20.00
ANTI ROLL BAR (REAR) PLUS LINK ARMS £20.00
WILL ACCEPT CHQ OR PAYPAL BUT WILL NEED TO ADD 5%.
DO HAVE SOME OTHER BITS AND BOBS LEFT, MAJOR STUFF LIKE INTERIOR, DOORS, BONNET, BOOT,LOOM, ENGINE & GEARBOX HAVE ALL BEEN SOLD.
Old Apr 1, 2006 | 07:43 PM
series1mike's Avatar
series1mike
Do you have any suspension left!!!!
Old Apr 1, 2006 | 08:04 PM
butterfly's Avatar
butterfly
Default SUSPENSION
Hi,
I have the rear beam & wishbone arms, front track control arms, front anti roll bar, rear anti roll bar with newish link arms and brackets.
Koni front springs available and one koni front shocker and still have the front spring caps and bearings.
Is there anything of use to you?.
Cheers Paul.
Tel:07730315451
Bristol area
Old Apr 1, 2006 | 08:09 PM
series1mike
im quite keen on the springs,
Old Apr 4, 2006 | 03:52 PM
ark1's Avatar
ark1
you got any leather door cards?
Old Apr 4, 2006 | 04:01 PM
PAUL S's Avatar
PAUL S
Hi
do you have the oil cooler modine for a 4x4 (the bit between the engine and oil filter with water pipes coming out of it - if so can you let me have a price
cheers
Old Apr 4, 2006 | 04:10 PM
butterfly's Avatar
butterfly
Default Interior
Hi,
All interior has gone.
Cheers Paul
Old Apr 4, 2006 | 04:11 PM
butterfly's Avatar
butterfly
Default OIL COOLER
STILL HAVE AVAILABLE PM.
jason_nike
Aug 18, 2019 10:53 AM
Caddyshack
Aug 19, 2015 07:29 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
Old ford
Jul 31, 2015 06:50 AM
