the best stand alone manegment
from the untold variations of aftermarket ecu's and manegement and whatnots, what do you all rate as the best?
which ones are the easiest to work with?
which ones have the most adaptability etc?
price of the basic unit with future add ons etc?
it's a minefield out there and i'm sure people will have differen onions about one or the other, but i'm after soemthing thats both affordable and will do the job i want it to do with the capability of fitting other stuff to do other stuff if i need to add/remove some functions
i've been thinking along the lines of mbe simply because it's something i know i can get set up fairly easily to get the car running, but what about things you build yourself like mega squirt and the like?
it's mainly to get the 2.3 4 pot working at the moment but i'm also thinking about the 24V TT application
any ideas much appreciated peeps
the basics are they all provide fuel @ a given air intake so with that regards they are all pretty much the same.
the rest is toys and add-ons.
the mapping is far more important than the management imo!
most of the cheaper ECUs (ie Emerald, DTA, T2, MBE, Omex etc.) aren't brilliant as boosted applications. They'll work, but you'll be able to get more driveability out of a proper system like Autronix, T6 etc. etc.
that being said, even the cheapest systems (ie megasquirt etc) will be fine for what you need, its just they might not be able to mimic the perfect driveability in all situations like EECIV can.
you cant use cossie mangement on the V6.
your best bet would be to get an EECIV ECU off an american 6pot turbo/SC car and use that and get it mapped by Ahmed or Stu@MSD
so, looks like megasquirt is leading teh way then
silly as it may sound, wft is all this L8 and P6 etc stuff about then?
is it just a more advanced management ecu or has it got loads of other goodies on it?
different versions of the ECU. the L1 was made in the early 80s so its a bit basic... the P8 is early 90s so its had 10 years worth of development in there.
the differences are mainly to do with more memory, faster processor etc. etc.
so, if i was to wire up cossie management to the 4 pot, it would work?
only just not for the forced induction bit of it?
and then i add a turbo and it's all fine and dandy?
yes, but you wouldnt get as good result doing that with cossie as you would with aftermarket.
for example, Emerald costs 550quid... (plus you'd need 2 diferent sensors, so about 20quid for them). for that you'd chop the loom plug off, rewire the new plug, job done.
cossie management will cost you about what 200-300quid? you'd need to get a cossie loom so say another 100, plus youd need to fuck about with things like phase sensors etc. etc. so fabrication etc. lots of messing etc.
you'd probably save only a few quid.
then youre left with a system YOU cant tweak
plus the aftermarket one will probably work better with the NASP car :P
when you considr megaquirt is about 200quid, it makes EVEN MORE sense
so, for my 2.3 scorpio engine that i can't use the normal scorpio loom on due to the pats stuff, i could get something simple like megasquirt, ready to run out of the box?
or
for the 24V blown application i could run the emerald?
sound about right?
or
sound about right?
Go for t2 or emerald. I think Sean Bicknell has it in his exige and swore by it.
dojj, i THINK the megasquirt can run both. but i personally wouldnt run a 24vTT on it, as its not exactly cutting edge technology. but then thats just my opinion
the cheaper ECUs (emerald, omex DTA etc.) will do you happily tho
no point cashing out for the likes of T6 as you wont use 1/4 of the features
ps i'm running emerald on mine and it works very well.
the only issue i have at the moment is poor transient fueling, but im pretty sure dave walker can map it so its perfect
mine goes in next monday to be mapped
good point jay.
just to clarify, the point i'm trying to make, as that some of the "boost" mapping on these ECUs is quite basic, moreso infact than some standard systems.
pectel T6 is the best ecu money can buy,, and there support is amazing, give you an example
i was out playing with my car the other day, and noticed for some strange reason the base map wasnt interpolating correctly, quick emals with my map and profile to pectel,,, email straight back, and they had found a small software glitch in my mapping program
mk3ste
Oct 17, 2021 10:09 AM
davidfox280585
Shows & Track Days
Sep 17, 2015 10:09 AM
