2 STAGE BOOST ISSUES....
Old Mar 31, 2006 | 11:10 AM
COSSIE 1's Avatar
COSSIE 1
Default 2 STAGE BOOST ISSUES....
The previous owner had a 2 stage boost kit fitted to the s2 its linked upto a switch but when i flick it nothing seems to happen......how do thy work etc..cheers
Old Mar 31, 2006 | 11:43 AM
Combi_Chris's Avatar
Combi_Chris
im not sure , but it could be as simple as switching the amal valve on and off >
someone will flame me down in the biggest possible way if i am wrong though
Old Mar 31, 2006 | 12:33 PM
Patto's Avatar
Patto
yep just a switch to the amal valve, mine has one on thanks to the previous owner, when i got it it was very hit and miss sometimes it worked sometimes it didnt unless i moved the wire on the A/V just soldered a new connection on and its fine now.
Old Apr 6, 2006 | 11:03 PM
COSSIE 1's Avatar
COSSIE 1
anymore ideas on this one peeps
Old Apr 7, 2006 | 05:53 AM
grunter's Avatar
grunter
if memory serves me correct u can either wire it in at the amal valve or cut into wire 9 on the ecu putting a switch inline i did it once on my old s1 worked well
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
Russ Payne
Sep 25, 2015 08:29 PM
