Aeroquip fittings
Old Mar 30, 2006 | 05:49 PM
JonnyBravo's Avatar
JonnyBravo
Default Aeroquip fittings
I'm just about to get round to doing the fuel system on TB'd car for a mate.
The fuel rail and regulator are all -6 fittings so I'll use aeroquip from the fuel rail to regulator, I will also fit a standard cosworth pump so I could fit -6 fittings to that.
Problem is that my mate will be running a full interior so I cannot run the lines from the tank inside the car.
Would you use aeroquip front to rear under the car or just stick to the original plastic pipe front to rear ?
Is there a -6 to push on pipe fitting available if I chose to go for plastic or rubber pipes front to rear ?
Thanks
James
Old Mar 30, 2006 | 05:54 PM
rsnissan's Avatar
rsnissan
you can get jubilee finishers for the hose to clamp on the "normal" likes
I have run my aeroquip under the car where the standard lines would have been.
Old Mar 30, 2006 | 06:04 PM
JonnyBravo's Avatar
JonnyBravo
Do the aeroquip lines go all crappy looking from being under the car ?
Old Mar 30, 2006 | 06:12 PM
rsnissan's Avatar
rsnissan
dunno havent driven mine yet
reckon they will look like braided brake hoses arfer a while unless you clean them up.
I cant be arsed with doing that though
Kyle Langford
27
Aug 5, 2019 07:54 PM
Oct 9, 2015 07:38 PM
ekjim
Aug 27, 2015 05:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
