Problem with brakes on a S2!
Old Mar 30, 2006 | 11:15 AM
Poom's Avatar
Poom
Default Problem with brakes on a S2!
Right,
The brakes were bled up before the engine was fitted as we removed the ABS and fitted new lines! It took some effort and loads of time but all seemed fine so then we fitted the engine.
Now it is all running there is no brake pedal, it is just going to the bottom as if all of the brake pressure has been lost!
The hose to the servo seems fine but has anybody got any other things to check or ideas what it could be?
Old Mar 30, 2006 | 01:45 PM
Eagle's Avatar
Eagle
Super Moderator
did you bleed the brakes with some weight on the rear end on the floor ?????
Old Mar 30, 2006 | 01:49 PM
Poom's Avatar
Poom
Nah it was jacked up as the front was on axel stands! Will it be that?
Old Mar 30, 2006 | 03:17 PM
adamS2RST's Avatar
adamS2RST
If it's still got the rear load valves then yes
Old Mar 30, 2006 | 03:19 PM
Poom's Avatar
Poom
Damnit
Yeah it was jacked up! Oh well I will let the garage do it on weds
Old Mar 30, 2006 | 03:43 PM
Wazzzer's Avatar
Wazzzer
get the rear end on axle stands (under the arms) so the load valves think the car is on the deck. Its not that hard, I did mine when I changed my rear calipers at the weekend
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
