water pump
Old Mar 29, 2006 | 04:52 PM
fleckyboy's Avatar
fleckyboy
Default water pump
how can you tell if your water pump is fooked ? changed the themostat + electric fan sensor but the engine is still getting WARM !! hope its not the head gasket ! no oil in header tank or mayo on the oil filler cap, is there a quick / easy way to check a water pump is dying ?
car is a fiesta turbo
cheers
rich
Old Mar 29, 2006 | 06:00 PM
derkymoon's Avatar
derkymoon
they usually leak water when buggered. Try flushing rad, with the flow and the other way see if its blocked
Old Mar 29, 2006 | 06:26 PM
fleckyboy's Avatar
fleckyboy
will try that cheers mate
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
