fiesta turbo* HELP!
Old Mar 28, 2006 | 12:57 PM
landy's Avatar
landy
Default fiesta turbo* HELP!
i have a standard 1.6 fiesta turbo and i cant stop the alternator blades from cottin thru the bottem rad hose i replaced all engine and gearbox mounts makes no diffrence i have also baught a new alternator and belt from fords! plz can some1 help!!!!!!!!!!!!!!!
Old Mar 28, 2006 | 02:30 PM
jonnyturbo's Avatar
jonnyturbo
is the radiator mounted properly? has the car ever been crashed and the front panel pushed inwards slightly?
Old Mar 28, 2006 | 04:59 PM
fiestaturbo1984's Avatar
fiestaturbo1984
as above check that the chassis leg isnt bent as this wont help
Old Mar 28, 2006 | 06:18 PM
gup's Avatar
gup
Default your belt
the only other option is to take the old belt off go to your nearest parts place and get a smaller fan belt ,my cousins series two was doing the same thing and now its spot on with a smaller belt not the best way but it will get you out of trouble for the time being
Old Mar 28, 2006 | 07:17 PM
SafeChav's Avatar
SafeChav
Default Re: your belt
Don't mention shorter belts I've got a series 2 rad in a MK3 cabby and FUCK ME is it close, ive got the smallest belt possible on there and with the alternator against the block u still have to lever it over the pulleys, and ive got about 2mm clearance
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
Marv888
Sep 26, 2015 03:44 PM
